Hi guys quick question,
Which is the the best, most accurate and most durable etc ultrasonic sensor to buy?
Feedback much appreciated.
M...
M...
Hard to say but based on what manufacturers claim , here's what I've heard :
SRF05 has 2 mm precision (that's what they say , sounds impossible)
US-100 has 3mm precision (that's what they say , sounds impossible)
US-020 has 3mm precision (that's what they say , sounds impossible)
and no info on HCSR04 but I guess its more than 1mm , otherwise they would've written in the description ![]()
I'd say the sort used for medical scanners.
They're durable, proof against moisture, high power, incredibly accurate.
Industrial ultrasonics . I thought only normal ultrasonics .
Depends what is the ultrasonic going to do , if it's avoiding a wall , 1mm or 10mm makes no difference as you should order the robot to turn with 20cm distance .
Just make sure it's Arduino-compatible and works with the NewPing or some other library .
