Best way to protect inputs from over voltages
I have an Arduino Nano 3.3BLE that will be used as a automotive fan controller. The controller senses up to 3 temperatures to control fan speed. At this point temperature control is pretty well understood. But I have a couple of analog input pins available that I may want to make use of.
Since this will be a universal controller those additional features are not defined as they will be at the users discretion of how to use and program them.
But in most cases these inputs may be used based on some automotive ~13.8V DC on or off type scenario which is too high for the 3.3V IO pins of the nano
So I would like to find the best way to assure any voltage coming into the IO pins is clipped to 3.3V max. In the attached schematic circuits A6 and A7 would be available as these types of inputs
Opto couplers.
Thanks for the reply. I get the opto but whats the LED for. This will all be in an enclosure, tucked deep under the dash board. Also I'm running a 3.3V Nano. Will those resistors change with 3.3V?
The 10 Ways to Destroy an Arduino may be of interest. It has a lot of info on protecting Arduinos.
Interesting read. I though #3 would be most relevant or are you seeing something I'm not seeing in my schematic?
They mention a rugedruino with protection on the I/O pins to 24 V but the link to it is broken.
Never mind I found the link. Maybe I should be sing one of these.
if you do not want to put or use the LED then it's your choice.
The LED limits the voltage on the Arduino pin to about 2V. A strange design.
Some better info about I/O protection:
There are many millions of imputs protected like this. It is very low cost and effective.
Greater protection can be had by using regular silicon diodes (Vf ~0.7V) followed by a resistor and a pair of schottky diodes. A bit belt and braces, but the automotive environment can be very harsh. The resistor values and capacitor value can vary from those in this diagram.
This diagram is from https://www.digikey.co.uk/en/articles/protecting-inputs-in-digital-electronics.
Zenner diods
There seam to be quite a few options here. I wont be commencing on this for some time but I do expect to get back to it. For the moment I am focusing on a board without these optional inputs.
Should be the last thing you're thinking of.
Clamping diodes also protect when the Arduino is off, zeners don't.
Leo..
Elaborate?
Zeners could work if max pin voltage would be 3.3volt (+0.3volt) or 5volt (+0.3volt).
But it's not.
Max pin voltage is VCC (+0.3volt).
If the Arduino is off, then VCC is 0volt, which makes max pin voltage 0.3volt.
A 3.3volt or 5volt zener won't protect anything in that case.
Clamping diodes dump excess pin voltage onto VCC, whatever that voltage currently is.
Leo..
Sorry, I’m confused by your explanation, could you please show me why you think there is a difference whether or not Arduino is powered on this diagram
When the Arduino is off...
If there is only 1volt on the 'Connector terminal', then nothing will flow into the 5.1V zener,
but current will flow into the pin through the MCU's internal clamping to the MCU's VCC.
Leo..
And? the question was how do you protect it from over voltage not from backfeeding
You call it backfeeding, but any current into (or out off) an input pin is what we try to avoid.
Voltage does not damage a pin, current does.
Leo..
Then go find a topic on current protection. you singled out my reply as if I suggested some nonsense when in fact it is a common way of doing it. Thanks for wasting my time
Looking at some of the conversation going on, I'm not sure if my request may have been mis-leading. The way these pins will be used is to tell if a circuit is on or off. The actual magnitude of the voltage doesn't matter. So in this case applying automotive voltage of ~ 14V is the normal operation and not a transient. The goal is to make 14V or preferably any signal that is too high just clipped down to a something usable on the 3.3V IO pins of the Arduino.
One of the other goals I have is to get the component count to a minimum. Space is getting tight especially when there are multiple circuits to fit in. I probably wont attempt this until I get up to speed with surface mounted components.
I like opto couplers as others have said, PC847 is available in quad IC.
https://www.futurlec.com/Datasheet/LED/PC817.pdf
schemeit-project
