Hey Arduino Community!
I'm really interested in building my own Powermeter for my Bicycle.
To give you an example:
But I don't want to send the date to a second Arduino, I would like to send it to my Garmin Edge 530 device. Does anyone of you have experience on that topic and could give me an overview how complicated this project would be and if it's possible to manage this project with a low level of arduino experience?
looking forward to your Answers!
Regards,
Felix
Thanks for your answer!
Most of the Projects with arduino and Garmin use ANT+. The Garmin Edge is also able to connect with a Bluetooth sensor, so I wondered if it wouldn't be easier to connect it with BT to the Arduino. However, I found nothing in my reseaches that someone connected a Arduino with Bluetooth to the Garmin, so I don't know if that would work.
// Programm zur Bestimmung des Neigungswinkels mittels Kalmanfilter und des MPU6050-Sensors
#include <SPI.h>
#include "RF24.h"
#include "Wire.h"
#include "I2Cdev.h" // I2Cdev and MPU6050 must be installed as libraries
#include "MPU6050.h" // class default I2C address is 0x68 = AD0 low
#include <math.h>
MPU6050 accelgyro;
int16_t ax, ay, az; // Beschleunigungswerte in x-,y- und z-Richtung des MPU6050-Sensors
int16_t gx, gy, gz; // Winkelgeschwindigkeitswerte in x-,y- und z-Richtung des MPU6050-Sensors
float data[2]; // per Funk übertragenes Datenarray für Leistung P, Umdrehungszeit tau etc.
int sensorPin = A0; // select the input pin for the force measurement
float Winkel_neu, Winkel_alt; // aktueller und alter Neigungswinkel
float gz_alt, gz_neu; // aktuelle und alte Winkelgeschwindigkeit
float time_alt, time_neu; // aktuelle und alte Zeit
float t_Umdrehung_Start; // Startzeit einer Umdrehung
float t_Umdrehung_Ende; // Endzeit einer Umdrehung
float t_Umdrehung; // Zeit für eine vollständige Umdrehung
float v; // Mittlere Pedalgeschwindigkeit
float r; // Kurbellänge
int n; // Anzahl der Kraftmessungen während einer Umdrehung
float F; // Mittelwert der während einer Umdrehung wirkenden Kraft
float k; // Kalibrierfaktor bzgl. welcher Zahlenwert [0,1023] welcher Kraft in Newton entspricht
int offset; // offset der Eingangsspannung noch ohne Belastung, also bei F = 0
float P; // mittlere Leistung P
// Funkmodul NRF24L01 mit Arduino-Pins verbinden:
// SCK -> 13 // MISO -> 12 // MOSI -> 11 // CSN -> 10 // CE -> 9
// SPI-Bus Pins 9 und 10
const uint64_t pipe = 0xE8E8F0F0E1LL; // Adresse des Übertragungskanals des NRF24L01
RF24 radio(9,10);
// ======== SETUP =======
radio.begin();
radio.openWritingPipe(pipe); // Sende-Kanal öffnen
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// initialize serial communication
// initialize device
accelgyro.initialize();
// read raw accel/gyro measurements from device
// Ausgabewerte-Acc: Auflösung 2g: 16384/g Auflösung 4g: 8192/g
// Ausgabewerte-Gyro: Auflösung 250°/s: 131/°/s ; 500°/s: 65.5/°/s ; 2000°/s: 16.375/°/s
//Sensor output scaling (2g,4g,8g,16g)
accelgyro.setFullScaleAccelRange(MPU6050_ACCEL_FS_8); // Sensor konkret auf 8g eingestellt
//Sensor output scaling (250°/s,500°/s,2000°/s)
accelgyro.setFullScaleGyroRange(MPU6050_GYRO_FS_500); // Sensor konkret auf 500°/s eingestellt
// verify connection
//Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
time_alt = 0.0;
Winkel_alt = 0.0;
gz_alt = 0.0;
r = 0.175; // Kurbellänge in m
k = 292.0; // Kalibrierfaktor in Newton/Volt
offset = 0.0; // offset ohne Belastung
for (int i = 0; i < 5; i++)
offset = offset + analogRead(sensorPin); // Ermittlung der mittleren (5 Messungen) offset-Spannung noch ohne Belastung
offset = offset / 5.0;
data[0] = 5000.0 * analogRead(sensorPin) / 1024.0; // einmalige Übergabe des Spannungswerts in mV ohne Belastung!
Serial.print(data[0]);
Serial.print(" ");
Serial.println(data[1]);
radio.write(data, 8); // ACHTUNG: Adresse (data) und Länge (pro float 4 byte, d.h. für 2 Zahlen 8 eintragen) der zu sendenden Daten!
delay(2000);
// ======== HAUPTSCHLEIFE =======
n = 0; // Zählvariable auf 0 gesetzt
F = 0; // Kraftmittelwert wird auf 0 gesetzt
t_Umdrehung_Start = micros(); // Ermittlung der Startzeit einer Umdrehung
do
accelgyro.getRotation(&gx, &gy, &gz); // Einlesen der aktuellen Winkelgeschwindigkeiten
// accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); // Einlesen der aktuellen Beschleunigungen und Winkelgeschwindigkeiten
gz_neu = -gz; // neue Winkelgeschwindigkeit
// Berechnung des neuen Winkel mittels altem Winkel und dem Mittelwert aus alter und neuer Winkelgeschwindigkeit:
time_neu = micros(); // aktuelle Laufzeit des Programms in µs
Winkel_neu = Winkel_alt + 0.5 * ((gz_alt + gz_neu) / 65.5) * ((time_neu - time_alt) / 1000000.0);
if (Winkel_neu < 0) // Neustart bei negativen Winkel
Winkel_neu = 0.0;
F = F + k * (5.0 * (analogRead(sensorPin) - offset) / 1023.0); // Integration über alle während einer Umdrehung wirkenden Kräfte; Faktor k = Newton/Volt !
Serial.print(Winkel_neu,0);
Serial.print(" ");
Serial.println(F/n,1);
data[0] = Winkel_neu;
data[1] = F / n;
// Werteübergabe
gz_alt = gz_neu;
time_alt = time_neu;
Winkel_alt = Winkel_neu;
n = n + 1; // Anzahl der Messungen um 1 erhöht
while (Winkel_neu < 360); // Ausstieg aus der Schleife, wenn der Winkel > 360°, sprich bei einer vollen Umdrehung
// == Vollständige Umdrehung ==
t_Umdrehung_Ende = micros(); // Ermittlung der Endzeit einer Umdrehung
Winkel_alt = Winkel_alt - 360.0; // Reduzierung des Winkels auf das Intervall [0,360]
F = F / n; // Berechnung der mittleren Kraft während einer Umdrehung
t_Umdrehung = (t_Umdrehung_Ende - t_Umdrehung_Start) / 1000000.0; // Berechnung der Umlaufszeit in Sekunden
v = 2.0 * r * 3.141592654 / t_Umdrehung; // Berechnung der mittleren Pedalgeschwindigkeit;
P = 2.0 * F * v; // Berechnung der mittleren Leistung P
// Datenübertragung per Funk
data[0] = P;
data[1] = t_Umdrehung;
Serial.print(" ");
Fine. Thanks.
Identify the radio specific details in the code and comment them out.
Then add the needed BT corresponding pieces.
Note that You need to install the BT system. You can't just change radio lines of code into any lookalike BT code.
Get comfortable with the use and setup of BT.
Many beginners search for a project to copy, and they waist their time. There is always code, circuitry eyc. that need "hands on".
