Bizzare motor behavior
Hey all,
I followed the following connection schematic for a dc motor with an H-bridge
My connection is below.
This is the following code I am running
//www.elegoo.com
//2016.12.12
Exercise the motor using
the L293D chip
#define ENABLE 5
#define DIRA 3
#define DIRB 4
int i;
  //---set pin direction
  pinMode(ENABLE,OUTPUT);
  pinMode(DIRA,OUTPUT);
  pinMode(DIRB,OUTPUT);
  //---back and forth example
    Serial.println("One way, then reverse");
    digitalWrite(ENABLE,HIGH); // enable on
    for (i=0;i<5;i++) {
      digitalWrite(DIRA,HIGH); //one way
      digitalWrite(DIRB,LOW);
      digitalWrite(DIRA,LOW);  //reverse
      digitalWrite(DIRB,HIGH);
  digitalWrite(ENABLE,LOW); // disable
  delay(2000);
I have videos of whats going on but it seems we cant upload videos. If that is necessary maybe I could upload them to youtube and link them.
I have not connected a battery to the breadboard power supply unit however the motor begins to turn (ie the program runs) though its slow. When i connect the battery it is faster.
Could someone please suggest what could be wrong with my connection or what could be causing the issue?
Edit: I think i can redefine my problem. Why could the motor run when pin 8 on the L293D is not connected to a battery?
If im understanding your reply, is it that pin 16 on the L293D should be connected to 5V on the arduino?
If so, I tried that and have just tried it again, unfortunately gives the same result
Ah and also the ground connections on the other side too I have tried those
Links to the behaviour im describing:
When battery is not connected
When battery connected
Please do not start multiple topics with the same subject.
Please, I'd endear you to fully read both. That was a circuit I tried setting up on tinkercad (actually to see if i could use software to figure up the problem i describe in this post), and this is another problem entirely.
I found the issue to the other problem too.
However I am stumped here, though I will move on for now. If you could please offer any help I'd be grateful.
Thank you
