Blades ?Antenna -wifi not working 33iot
1.33IOT wifi - blades ?
I was experimenting with 33IOT when all of a suddenly i can't seem to connect to wifi. ( it was fine before )
Been trying endlessly. Then i look at the board and realise, you know the Wifi Blox module, next to it ( or rather part of it ) there is some time of a metal blade , which i call the guillotine. It seems to be "loose" and not sticking well anymore.
What is this "blade " - wifi antenna ? So it has something to do with the wifi not working ?
Yes it's the antenna for WiFi and BT
may be, may be not
It looks like the tabs that hold the antenna to the PCB have popped loose from where they are soldered to the PCB. You could re-solder them.
The electrical connection to the antenna is essential to the board's Wi-Fi capabilities. The solder joint that provides the electrical connection is broken.
I accidentally broke mine a few weeks ago, removed the whole metal part, but works correctly after re-soldering. Be careful and absolutely never remove it from a breadboard by pulling that part, haha.
