Can anybody help me with the Arduino Uno? I want to program a tactile switch as a toggle/latch switch and then be able to switch on a blinking LED and then switch it off again. I’m very much a beginner.
Welcome to the forum
Start by looking at the StateChangeDetection example in the IDE to see how to detect when an input changes its state rather than when it is in a particular state
Once the code has detected a change of state from say HIGH to LOW then set a boolean variable to true to flag the fact that blinking is occurring
In loop(), if the boolean is true use the technique in the BlinkWithoutDelay example to turn the LED on and off without blocking the detection of further button presses
you need two parts:
a) debounce a button to switch a state on / off
b) blink a LED
a) is explained in the IDE examples called "Debounce"
b) is explained in the IDE as "Blink without Delay"
if you don't want to learn c++, you can use my library:
https://werner.rothschopf.net/microcontroller/202202_tools_led_en.htm
quick demo:
#include <Noiasca_led.h> // download library from http://werner.rothschopf.net/microcontroller/202202_tools_led_en.htm
#include <utility/Noiasca_discrete.h> // use the discrete pins on the Arduino/Microcontroller
#include <Noiasca_button.h> // some tools to read buttons
BlinkPin blinkLed {13}; // declare several blinking LED and assign pins
Button button {A0}; // button connects pin with GND, "active LOW"
blinkLed.begin(); // you have to call the .begin() method for each LED object
blinkLed.on(); // you can switch the blinking on in setup
button.begin(); // you have to call the .begin() method for each button
// optional: you can set different blink intervals for your LEDs
blinkLed.setOnInterval(500);
blinkLed.setOffInterval(200);
if (button.wasPressed())
Serial.println(F("button 0 was pressed, switch ON LED 0"));
blinkLed.toggle(); // if button was pressed, toggle (change state) of blinkLed
blinkLed.update(); // you have to call update() for each LED
Hello
In this class less example are running the same parts, as mentioned by my dear user noiasca.
Take some time and play around. This example is running with three sets of buttons and leds.
enum Control {Off, On};
struct TIMER
const unsigned long Interval;
unsigned long previousMillis;
int onOff;
struct BUTTON2LED
const byte LedPin;
const byte ButtonPin;
int actionState;
int stateOld;
TIMER flash;
TIMER debounce;
} button2Leds[] {
{9, A0, Off, Off, 1000, 0, Off, 20, 0, On},
{10, A1, Off, Off, 1000, 0, Off, 20, 0, On},
{11, A2, Off, Off, 1000, 0, Off, 20, 0, On},
for (auto &button2Led : button2Leds)
pinMode (button2Led.ButtonPin, INPUT_PULLUP);
pinMode (button2Led.LedPin, OUTPUT);
digitalWrite (button2Led.LedPin, On);
delay (1000);
digitalWrite (button2Led.LedPin, Off);
for (auto &button2Led : button2Leds) {
if (currentMillis - button2Led.debounce.previousMillis >= button2Led.debounce.Interval)
button2Led.debounce.previousMillis = currentMillis;
int stateNew = !digitalRead(button2Led.ButtonPin);
if (button2Led.stateOld != stateNew)
button2Led.stateOld = stateNew;
if (stateNew) button2Led.actionState = !button2Led.actionState;
digitalWrite (button2Led.LedPin, button2Led.actionState);
if (currentMillis - button2Led.flash.previousMillis >= button2Led.flash.Interval && button2Led.actionState)
button2Led.flash.previousMillis = currentMillis;
digitalWrite (button2Led.LedPin, !digitalRead (button2Led.LedPin));
