Bluetooth data ASCII
I’m trying to extract data that I send to a bluetooth module (DSDtech HM-19) but the problem is that if I send a number, the one received by the arduino isn’t the same. If I send 1, the arduino receives 49 or if I send 22 the arduino receives 5050. It appears to be ASCII code but I can’t find a way to convert it if it is more than a simple number ( - ‘0’). Is there a function or something to do this ?
Use Serial.write(f)
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You could convert each character as it is read instead of trying to convert a multi digit number all at once
Or you could put each character in an array of chards as it is read, add a '\0' to the end to turn it into a C style string then use atio() to convert it to an integer
Or you could use Serial.parseInt() to do teh job for you
Hello thebiiche
change
int f;
to
char f;
Using char instead of int didn’t change anything but here is the complete project, I just want to send a frequence to my arduino so that it plays it.
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(2,3);
char c = '0';
int f;
  pinMode(12, OUTPUT);
  BTSerial.begin(9600);
  if (BTSerial.available()) {
    c = BTSerial.read();
    f = c-'0';
  if (c == 0) {
    noTone(12);
    Serial.print(c);
    BTSerial.print("OFF");
  else {
    tone(12,f);
    Serial.print(c);
    BTSerial.print("ON");
