BMI160 Issue
Hi
I am using BMI160 shuttle board with Arduino Uno over SPI. Also I am using the Driver developed by Hanyazou GitHub - hanyazou/BMI160-Arduino. The connection is okay but the gyro results are incorrect. Can you please help me resolve the issue?
Please see the code below (The code is the example in the Hanyazou GitHub).
[code]#include <BMI160.h>
#include <BMI160Gen.h>
#include <CurieIMU.h>
//const int i2c_addr = 0x69;
  Serial.begin(9600); // initialize Serial communication
  while (!Serial);    // wait for the serial port to open
  // initialize device
  Serial.println("Initializing IMU device...");
  BMI160.begin(BMI160GenClass::SPI_MODE, /* SS pin# = */10);
  //BMI160.begin(BMI160GenClass::I2C_MODE);
  uint8_t dev_id = BMI160.getDeviceID();
  Serial.print("DEVICE ID: ");
  Serial.println(dev_id, HEX);
  // Set the accelerometer range to 250 degrees/second
  BMI160.setGyroRange(125);
  Serial.println("Initializing IMU device...done.");
  int gx, gy, gz;         // raw gyro values
  // read raw gyro measurements from device
  BMI160.readGyro(gx,gy,gz);
  // display tab-separated gyro x/y/z values
  Serial.print("g:\t");
  Serial.print(gx);
  Serial.print("\t");
  Serial.print(gy);
  Serial.print("\t");
  Serial.print(gz);
  delay(1);
float convertRawGyro(int gRaw) {
  // since we are using 250 degrees/seconds range
  // -250 maps to a raw value of -32768
  // +250 maps to a raw value of 32767
  float g = (gRaw * 250.0) / 32768.0;
  return g;
   Copyright (c) 2016 Intel Corporation.  All rights reserved.
   This library is free software; you can redistribute it and/or
   modify it under the terms of the GNU Lesser General Public
   License as published by the Free Software Foundation; either
   version 2.1 of the License, or (at your option) any later version.
   This library is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
   Lesser General Public License for more details.
   You should have received a copy of the GNU Lesser General Public
   License along with this library; if not, write to the Free Software
   Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
[/code]
