[BMP085 barometer sensor] Convergence speed issue
Hello,
I am using the barometer sensor (BMP085) to measure a pressure in order to estimate an altitude.
My environment setting is Arduino pro-mini and Arduino IDE 1.0.4.
I measured pressure at a specific height and moved the sensor to other height and measured pressure at that height. After then, I measured pressure again at the original position.
The problem is that the convergence speed is so slow.
The sensor frequency is about 20Hz. But, It takes about 4 minutes until reaching the constant pressure at a different height.
I attached a graph to easily understand my situation.
Is my setting(BMP085, Arduino pro-mini, IDE 1.0.4) having any problems?!
Do you have any words of advice?
Thanks.
I've used these devices, and found them quite noisy, so a smoothing algorithm is required, but much faster than 4 minutes... more like a second or so. perhaps yours is faulty?
regards
Allan
