PS C:\Users\azzki\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 22192
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/azzki/.theia'
root INFO Theia app listening on http://localhost:52227.
root WARN The local plugin referenced by local-dir:/c%3A/Users/azzki/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/azzki/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\azzki\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.2" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root WARN Backend DefaultWorkspaceServer.onStart is slow, took: 2300.7 ms
root INFO Deploying backend plugin "cortex-debug@0.3.10" from "C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension"
root INFO Deploying backend plugin "vscode-arduino-tools@0.0.2-beta.2" from "C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle"
root INFO Deploying backend plugin "cpp@1.52.1" from "C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension"
root INFO Deploying backend plugin "json@1.46.1" from "C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension"
root INFO Deploying backend plugin "json-language-features@1.46.1" from "C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain"
root INFO Deploy plugins list took: 2338.8 ms
daemon INFO Starting daemon from C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
root WARN Backend ConfigServiceImpl.onStart is slow, took: 120.6 ms
daemon INFO Using config file: c:\Users\azzki\.arduinoIDE\arduino-cli.yaml
daemon INFO arduino-cli.exe version 0.21.0
daemon INFO Executing `arduino-cli daemon`
daemon INFO Setting up Prometheus metrics on :9090/metrics
daemon INFO {"IP":"127.0.0.1","Port":"52229"}
daemon INFO Daemon is running.
daemon INFO Adding libraries dir [dir: c:\Users\azzki\OneDrive\Documents\Arduino\libraries, location: user]
daemon INFO URL: https://downloads.arduino.cc/packages/package_index.json
daemon INFO Updating index [url: https://downloads.arduino.cc/packages/package_index.json]
root INFO Git askpass helper is listening on http://127.0.0.1:54759.
root WARN Frontend CommonFrontendContribution.configure is slow, took: 400.8 ms
root WARN Failed to resolve module: @types/body-parser
root WARN Failed to resolve module: @types/cookie
root WARN Failed to resolve module: @types/dompurify
root WARN Failed to resolve module: @types/express
root WARN Failed to resolve module: @types/fs-extra
root WARN Failed to resolve module: @types/lodash.debounce
root WARN Failed to resolve module: @types/lodash.throttle
root WARN Failed to resolve module: @types/markdown-it
root WARN Failed to resolve module: @types/react
root WARN Failed to resolve module: @types/react-dom
root WARN Failed to resolve module: @types/react-virtualized
root WARN Failed to resolve module: @types/route-parser
root WARN Failed to resolve module: @types/safer-buffer
root WARN Failed to resolve module: @types/ws
root WARN Failed to resolve module: @types/yargs
root WARN Failed to resolve module: @theia/monaco
root WARN Failed to resolve module: @theia/editor
root WARN Failed to resolve module: @types/multer
root WARN Failed to resolve module: @types/rimraf
root WARN Failed to resolve module: @types/tar-fs
root WARN Failed to resolve module: @types/uuid
root WARN Failed to resolve module: @theia/navigator
root WARN Failed to resolve module: @types/p-queue
root WARN Failed to resolve module: @theia/preferences
root WARN Failed to resolve module: @theia/editor-preview
root WARN Failed to resolve module: @theia/keymaps
root WARN Failed to resolve module: @theia/messages
root WARN Failed to resolve module: @types/diff
root WARN Failed to resolve module: @types/mime
root WARN Failed to resolve module: filenamify
root WARN Failed to resolve module: @types/request
root WARN Failed to resolve module: @types/atob
root WARN Failed to resolve module: @types/auth0-js
root WARN Failed to resolve module: @types/btoa
root WARN Failed to resolve module: @types/dateformat
root WARN Failed to resolve module: @types/deepmerge
root WARN Failed to resolve module: @types/glob
root WARN Failed to resolve module: @types/google-protobuf
root WARN Failed to resolve module: @types/js-yaml
root WARN Failed to resolve module: @types/keytar
root WARN Failed to resolve module: @types/ncp
root WARN Failed to resolve module: @types/node-fetch
root WARN Failed to resolve module: @types/ps-tree
root WARN Failed to resolve module: @types/react-select
root WARN Failed to resolve module: @types/react-tabs
root WARN Failed to resolve module: @types/temp
root WARN Failed to resolve module: @types/which
root ERROR Error: Git installation not found.
at C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\find-git-exec\lib\find-git-exec.js:85:69
at async DefaultGitInit.init (C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\theia\git\git-init.js:22:49)
root ERROR DefaultJsonSchemaContribution.registerSchemas is taking more than 500.0 ms, new schemas are ignored.
root ERROR Error while updating index in attempt 0.
root ERROR Error while updating index in attempt 1.
root ERROR Error while updating index in attempt 2.
root ERROR Error while updating index in attempt 3.
root ERROR Error while updating index in attempt 4.
root ERROR Error while updating index in attempt 5.
root ERROR Error while updating index in attempt 6.
root ERROR Error while updating index in attempt 7.
root ERROR Error while updating index in attempt 8.
root ERROR Error while updating index in attempt 9.
daemon INFO Updating libraries index
root ERROR Error while updating library index in attempt 0.
root ERROR Error while updating library index in attempt 1.
root ERROR Error while updating library index in attempt 2.
root ERROR Error while updating library index in attempt 3.
root ERROR Error while updating library index in attempt 4.
root ERROR Error while updating library index in attempt 5.
root ERROR Error while updating library index in attempt 6.
root ERROR Error while updating library index in attempt 7.
root ERROR Error while updating library index in attempt 8.
root ERROR Error while updating library index in attempt 9.
daemon INFO Checking signature [index: c:\Users\azzki\AppData\Local\Arduino15\package_index.json, signaturefile: c:\Users\azzki\AppData\Local\Arduino15\package_index.json.sig, trusted: true]
root ERROR Loading index file: loading json index file c:\Users\azzki\AppData\Local\Arduino15\package_CircuitMess_Ringo_index.json: open c:\Users\azzki\AppData\Local\Arduino15\package_CircuitMess_Ringo_index.json: The system cannot find the file specified.
root ERROR Loading index file: loading json index file c:\Users\azzki\AppData\Local\Arduino15\package_damellis_attiny_index.json: open c:\Users\azzki\AppData\Local\Arduino15\package_damellis_attiny_index.json: The system cannot find the file specified.
daemon INFO Loading hardware from: c:\Users\azzki\AppData\Local\Arduino15\packages
daemon INFO Loading package arduino from: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\hardware
daemon INFO Checking signature [error: opening signature file: open C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\installed.json.sig: The system cannot find the file specified., index: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\installed.json, signaturefile: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\installed.json.sig]
daemon INFO Adding monitor tool [protocol: serial, tool: builtin:serial-monitor]
daemon INFO Loaded platform [platform: {ID:"arduino:avr",Installed:"1.8.5",Latest:"1.8.5",Name:"Arduino AVR Boards"}]
daemon INFO Checking existence of 'tools' path: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loading tools from dir: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loaded tool [tool: Version: 1.3.0 Systems: [OS: i686-linux-gnu, OS: x86_64-linux-gnu, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: i386-apple-darwin11, OS: i686-mingw32]]
daemon INFO Loaded tool [tool: Version: 7.3.0-atmel3.6.1-arduino7 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin14, OS: i686-mingw32, OS: i686-linux-gnu, OS: x86_64-linux-gnu]]
daemon INFO Loaded tool [tool: Version: 6.3.0-arduino17 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin12, OS: x86_64-linux-gnu, OS: i686-linux-gnu, OS: i686-mingw32]]
daemon INFO Loading package builtin from: C:\Users\azzki\AppData\Local\Arduino15\packages\builtin
daemon INFO Checking existence of 'tools' path: C:\Users\azzki\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loading tools from dir: C:\Users\azzki\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loaded tool [tool: Version: 5.8-arduino11 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu]]
daemon INFO Loaded tool [tool: Version: 1.0.5 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 1.3.2 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Loaded tool [tool: Version: 0.9.1 Systems: [OS: i686-pc-linux-gnu, OS: x86_64-pc-linux-gnu, OS: i686-mingw32, OS: x86_64-mingw32, OS: x86_64-apple-darwin, OS: arm-linux-gnueabihf, OS: arm64-linux-gnueabihf]]
daemon INFO Adding libraries dir [dir: C:\Users\azzki\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries, location: platform]
daemon INFO starting discovery builtin:serial-discovery process
daemon INFO starting discovery builtin:mdns-discovery process
daemon INFO started discovery builtin:serial-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.21.0" to discovery builtin:serial-discovery
daemon INFO started discovery builtin:mdns-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.21.0" to discovery builtin:mdns-discovery
daemon INFO from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO sending command START_SYNC to discovery builtin:mdns-discovery
daemon INFO sending command START_SYNC to discovery builtin:serial-discovery
daemon INFO from discovery builtin:mdns-discovery received message type: start_sync, message: OK
daemon INFO from discovery builtin:serial-discovery received message type: start_sync, message: OK
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM3
root ERROR Request repositories failed with error: Git could not be found at the expected path: 'C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\dugite-no-gpl\git\cmd\git.exe'. This might be a problem with how the application is packaged, so confirm this folder hasn't been removed when packaging.
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 48288.6 ms
root WARN Frontend WorkspaceService.onStart is slow, took: 276.1 ms
root INFO Board config changed:
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
Checking for update
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75] Waiting for backend deployment took: 313.4 ms [Finished 51.084 s after frontend start]
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836) starting instance
serial-service INFO >>> Disposing serial connection...
serial-service WARN <<< Not connected. Nothing to dispose.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75] Sync of 5 plugins took: 255.7 ms [Finished 51.340 s after frontend start]
Update for version 2.0.0-rc5 is not available (latest version: 2.0.0-rc5, downgrade is allowed).
root INFO <<< The layout has been successfully restored.
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][marus25.cortex-debug]: Loaded contributions.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.cpp]: Loaded contributions.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.json]: Loaded contributions.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.json-language-features]: Loaded contributions.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75] Load contributions of 5 plugins took: 98.9 ms [Finished 52.457 s after frontend start]
root INFO Finished loading frontend application after 52.505 seconds
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): initializing(cortex-debug@0.3.10 with C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 29836] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): initializing(vscode-arduino-tools@0.0.2-beta.2 with C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): initializing(cpp@1.52.1 with C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): initializing(json@1.46.1 with C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): initializing(json-language-features@1.46.1 with C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): PluginManagerExtImpl/loadPlugin(C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 29836] PLUGIN_HOST(29836): PluginManagerExtImpl/loadPlugin(C:\Users\azzki\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][marus25.cortex-debug]: Started plugin.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][arduino.vscode-arduino-tools]: Started plugin.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.cpp]: Started plugin.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.json]: Started plugin.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75][vscode.json-language-features]: Started plugin.
root INFO [ac50f131-ed65-4e2c-a13c-c82ba7c93d75] Start of 5 plugins took: 751.6 ms [Finished 53.214 s after frontend start]
root INFO Starting language server: arduino:avr:uno
root INFO Changed application state from 'initialized_layout' to 'ready'.
daemon INFO inventory.Store.ConfigFileUsed() c:\Users\azzki\AppData\Local\Arduino15\inventory.yaml
daemon INFO Searching tools required for board arduino:avr:uno
daemon INFO Required tool [tool: {ToolName:"arduinoOTA",ToolVersion:"1.3.0",ToolPackager:"arduino"}]
daemon INFO Required tool [tool: {ToolName:"avr-gcc",ToolVersion:"7.3.0-atmel3.6.1-arduino7",ToolPackager:"arduino"}]
daemon INFO Required tool [tool: {ToolName:"avrdude",ToolVersion:"6.3.0-arduino17",ToolPackager:"arduino"}]
daemon INFO Resolving include SPI.h for arch avr
daemon INFO found better lib [lib: SPI, prio: 64C]
[30288:0315/181003.525:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
I think this is what you are looking for.
