Bounce library info and definitions and playground?
Hi there
I'm trying to learn and use the bounce library for buttons. There are quite a few functions in the library but not really any info exists about what each function does. The arduino playground which usually has humanized definitions has been replaced with bounce2 and all the definitions for the fubpnctions are not out there.
I've also tried doing a general search for functions like bounce() arduino and gives me nothing but debounce() info then changes my queries to debounce() after the first page.
Can some one please point to a place that has actuall info on each function.
I don't understand why this info was removed from the playground page and assumes you already know what your doing and what each function means.
You want to use Bounce2
I use the SwitchManager by Nick Gammon.
See example:
/*SwitchManager skeleton
 This sketch is to introduce new people to the SwitchManager library written by Nick Gammon
 The library handles switch de-bouncing and provides timing and state change information in your sketch.
 The SwitchManager.h file should be placed in your libraries folder, i.e.
 C:\Users\YourName\Documents\Arduino\libraries\SwitchManager\SwitchManager.h
 You can download the library at:
 http://gammon.com.au/Arduino/SwitchManager.zip    Thank you Nick!
 In this example we have 2 normally open (N.O.) switches connected to the Arduino - increment and decrement.
 The increment switch will also be used as a "Reset" switch if pressed for more than two seconds.
 The two switches are connected between GND (0 volts) and an Arduino input pin.
 The library enables pull-up resistors for your switch inputs.
 Pushing a switch makes its pin LOW. Releasing a switch makes its pin HIGH.
 The SwitchManager library provides 10ms de-bounce for switches.
 i.e. enum { debounceTime = 10, noSwitch = -1 };
 If you need more time, edit the SwitchManager.h file
 i.e. enum { debounceTime = 50, noSwitch = -1 }; //here it is changed to 50ms
#include <SwitchManager.h>
//object instantiations
SwitchManager myIncSwitch;
SwitchManager myDecSwitch;
unsigned long currentMillis;
unsigned long heartBeatMillis;
unsigned long heartFlashRate  = 500UL; // time the led will change state
unsigned long incShortPress   = 500UL; // 1/2 second
unsigned long incLongPress    = 2000UL;// 2 seconds
unsigned long decShortPress   = 500UL; // 1/2 second
const byte heartBeatLED       = 13;
const byte incSwitch          = 4; //increment switch is on Arduino pin 4
const byte decSwitch          = 5; //decrement switch is on Arduino pin 5
int myCounter;
  //gives a visual indication if the sketch is blocking
  pinMode(heartBeatLED, OUTPUT);
  myIncSwitch.begin (incSwitch, handleSwitchPresses);
  myDecSwitch.begin (decSwitch, handleSwitchPresses);
  //the handleSwitchPresses() function is called when a switch changes state
} //                   E N D  O F  s e t u p ( )
  //leave this line of code at the top of loop()
  currentMillis = millis();
  //some code to see if the sketch is blocking
  if (CheckTime(heartBeatMillis, heartFlashRate, true))
    //toggle the heartBeatLED
    digitalWrite(heartBeatLED,!digitalRead(heartBeatLED));
  //check to see what's happening with the switches
  //"Do not use delay()s" in your sketch as it will make switch changes unresponsive
  //Use BlinkWithoutDelay (BWD) techniques instead.
  myIncSwitch.check ();
  myDecSwitch.check ();
  //put other non-blocking stuff here
} //                      E N D  O F  l o o p ( )
//                          F U N C T I O N S
//                        C h e c k T i m e ( )
//Delay time expired function
//parameters:
//lastMillis = time we started
//wait = delay in ms
//restart = do we start again
boolean CheckTime(unsigned long  & lastMillis, unsigned long wait, boolean restart)
  //has time expired for this task?
  if (currentMillis - lastMillis >= wait)
    //should this start again?
    if(restart)
      //yes, get ready for the next iteration
      lastMillis = millis();
    return true;
  return false;
} //                 E N D   o f   C h e c k T i m e ( )
//                h a n d l e S w i t c h P r e s s e s ( )
void handleSwitchPresses(const byte newState, const unsigned long interval, const byte whichPin)
  //  You get here "ONLY" if there has been a change in a switches state.
  //When a switch has changed state, SwitchManager passes this function 3 arguments:
  //"newState" this will be HIGH or LOW. This is the state the switch is in now.
  //"interval" the number of milliseconds the switch stayed in the previous state
  //"whichPin" is the switch pin that we are examining
  switch (whichPin)
    //are we dealing with this switch?
  case incSwitch:
    //has this switch gone from LOW to HIGH (gone from pressed to not pressed)
    //this happens with normally open switches wired as mentioned at the top of this sketch
    if (newState == HIGH)
      //The incSwitch was just released
      //was this a short press followed by a switch release
      if(interval <= incShortPress)
        Serial.print("My counter value is = ");
        myCounter++;
        if(myCounter > 1000)
          //limit the counter to a maximum of 1000
          myCounter = 1000;
        Serial.println(myCounter);
      //was this a long press followed by a switch release
      else if(interval >= incLongPress)
        //we could also have an upper limit
        //if incLongMillis was 2000UL; we could then have a window between 2-3 seconds
        //else if(interval >= incLongMillis && interval <= incLongMillis + 1000UL)
        //this could be used to change states in a StateMachine
        //in this example however, we will just reset myCounter
        myCounter = 0;
    //if the switch is a normally closed (N.C.) and opens on a press this section would be used
    //the switch must have gone from HIGH to LOW
      Serial.println("The incSwitch was just pushed");
    break; //End of case incSwitch
  case decSwitch:
      //The decSwitch was just released
      if(interval <= decShortPress)
        myCounter--;
        if(myCounter < 0)
          //don't go below zero
          myCounter = 0;
      Serial.println("The decSwitch switch was just pushed");
    break; //End of case decSwitch
    //Put default stuff here
    //default:
    //break; //END of default
  } //End switch (whichPin)
} //      E n d   o f   h a n d l e S w i t c h P r e s s e s ( )
//                      E N D  O F  C O D E
There is also this:
Ok I'm using a teensy. I was using code meant for arduino to run my buttons but I was getting problem after problem using the library. So the guys at teensy said use bounce. I found a couple examples to help me figure out how to do button presses but my problem is that I need a repeat function to keep the button press as sending signal.
I know there are things in the library to help me solve the problem but no relevant information can be found on what each function in either bounce or bounce 2 to help me learn how each function works.
I can look at code and samples all day but with out proper info literally flying blind.
Here's the documentation for the Bounce2 library:
