Braces and if statement
I have been working on this for months and am really close. It is a fish feeder. There will be a gnome fishing and using a mp3 player he calls the fish. I am very proud of myself. I have solved a lot of problems not just coding but 3d printing and using hardware too. My family is visiting next week and I am hoping to finish it. Could I get some clue as to how to fix my latest problem I am pretty sure it is the braces. The fish feeder goes off at the first feed but continues to go through feeds 2, 3 and 4. Just a clue please to start me off?
/// Richard's fish pond sketch
/// Using the existing automatic fish feeder manual button
/// I will program an arduino to keep real time and play a
/// sound before the programmed fish feeding time. It will
/// then operate a servo to press the override button on the
/// fish feeder to release fish food. There will be an
/// over-ride button on the exterior of the box to operate it
/// at any-time.It will play a voice recording on a MP3 player.
/// Featuring rtc1307, MP3, thermometer, LCD, button
/// still to add humidity and temp DHT11
/// MP3
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(0, 1); // RX, TX10,11
DFRobotDFPlayerMini myDFPlayer;
////////rtc1307
#include "RTCDS1307.h"
RTCDS1307 rtc(0x68);
///LCD
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
////Thermometer
#include <DallasTemperature.h>
#include <OneWire.h>
int pDigitalTemp = 7;
int deviceCount = 0;
float tempC;
OneWire oneWire(pDigitalTemp);
DallasTemperature sensor ( &oneWire);
////RTClock
uint8_t year, month, weekday, day, hour, minute, second;
bool period = 0;
String m[12] = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
String w[7] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
///Button
const int buttonPin1 = 2;     // the number of the pushbutton pin
int buttonState1 = 0;         // variable for reading the pushbutton status
////Servo
#include <Servo.h>
int pos = 30;
Servo feed;
  ////servo
  feed.attach(A3);///was 4
  ////button
  pinMode(buttonPin1, INPUT);
  mySoftwareSerial.begin(9600);///////
  if (!myDFPlayer.begin(mySoftwareSerial));
  Wire.begin();///temp?
  ///Serial.begin(9600); Again, this prevents MP3 player from working?
  rtc.begin();
  ///rtc.setDate(24, 1, 23);
 /// rtc.setTime(9, 54, 01); //// hour, minute, second
  ///Initiate the LCD
  lcd.init();
  lcd.backlight();
  lcd.begin(16, 2);  // initialize the lcd for 16 chars 2 lines, turn on backlight
  lcd.backlight(); // LCD backlight on
  lcd.clear();
  delay(100);
  rtc.getDate(year, month, day, weekday);
  rtc.getTime(hour, minute, second, period);
  if (!(second % 3)) rtc.setMode(1 - rtc.getMode());
  lcd.clear();
  lcd.setCursor(0, 0);
  if (hour == 11) {
    lcd.clear();
    lcd.print("operate servo");
  delay(200);
  lcd.clear();
  lcd.setCursor(6, 0);
  lcd.print("Time ");
  lcd.setCursor(5, 1);
  lcd.print(hour, DEC);
  lcd.print(':');
  if ( minute < 10 ) {
    lcd.print('0');
  lcd.print(minute, DEC);
  lcd.print(rtc.getMode() ? (period ? " PM" : " AM") : "");
  delay(2000); // delay 1 seconds
  lcd.clear();
  lcd.print("Pond temperature");
    sensor.requestTemperatures();
        lcd.clear();
    lcd.print("Pond Temperature");
    lcd.setCursor(1, 1);
    lcd.print(sensor.getTempCByIndex(0));
     lcd.print((char)223);
    lcd.print("Celcius");
    delay(3000);
  /// calculate time until next feed?
  ///operate OLEDs?
  /// First feed
  if (hour == 10) {
    if (minute == 14) {
      lcd.clear();
      lcd.print("Breakfast!");
      delay(100);///1800000
      myDFPlayer.volume(30);///set volume to 30
      myDFPlayer.play(001);
      delay(10000);
      delay(8000);
      ///now operate servo
        for (pos = 30; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
          feed.write(pos);              // tell servo to go to position in variable 'pos'
          delay(15);                       // waits 15 ms for the servo to reach the position
        delay(1200);
        for (pos = 0; pos <= 30; pos += 1) { // goes from 0 degrees to 180 degrees
          // in steps of 1 degree
  ///2nd feed
  if (hour == 13) {
    if (minute == 00) {
      lcd.clear();
      lcd.print("Lunch!");
      delay(180);
      myDFPlayer.volume(20);///set volume to 30
      delay(10000);
      delay(8000);
        delay(1200);
  /// 3rd feed
  if (hour == 16) {
    if (minute == 00) {
      lcd.clear();
      lcd.print("Afternoon snack");
      delay(180);
      delay(10000);
      delay(8000);
        delay(1200);
  /// 4th feed
  if (hour == 18) {
    if (minute == 00) {
      lcd.clear();
      lcd.print("Dinner time!");
      delay(180);
      delay(10000);
      delay(8000);
        delay(1200);
  buttonState1 = digitalRead(buttonPin1);
  ///  check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState1 == HIGH) {
    delay(10000);
    delay(8000);
      delay(1200);
"Braces"
What indications (audio, LCD, servo) do you get when the feedings do not stop?
  • Placing delay(. . .) in your sketch should be avoid.
  • When this evaluates, how many times will the code in the { } braces executed ?
  if (hour == 11)
    lcd.clear();
At a glance, besides a few unnecessary pairs of { braces } and one or two not lined up for humans, this does not look like the problem you think it is.
I see
and advise you to move the software serial off the hardware serial pins.
Does the time and date such as you publish to the LCD seem plausible?
a7
Many prefer to use INPUT_PULLUP on the buttons and buttonState == LOW.
Easy enough to check curley braces "pairs" to see if they are in the correct places and if enough/too many etc.
Click beside each and the corresponding one will be shown.
Yet. But soon enough Imma probably say that serial printing may be a better verify and tracing means than using the LCD.
a7
Is this why Serial.begin(9600); prevents MP3 player from working?
Braces are curly brackets. Curly braces would be curly curly brackets!
Thanks Larry, I am aware of this and have studied using milliseconds instead but cannot get my head around it. I appreciate your comments.
Thanks Bluejets. I had noticed the "pairs" tip on the sketch but had not really understood it. Thanks to your comment I have a better understanding and am using it a lot to assist me. I appreciate your comments.
Thanks Alto77. It was not the braces, thanks. I am beginning to get an understanding
of the pins. I will not change them as I have soldered them on a shield.
I appreciate your help.
