Break beam sensor with servo for table tennis robot...HELP
Hi good people of Arduino forum, I hope U can help me.
I am building table tennis robot, and I need to make some cool drills with it.
I want to control movement of tube (servo motor - left right)
This is my starting point
And code:
      IR Breakbeam sensor demo!
    #define LEDPIN 13
      // Pin 13: Arduino has an LED connected on pin 13
    #define SENSORPIN 4
    // variables will change:
    int sensorState = 0, lastState=0;         // variable for reading the pushbutton status
      // initialize the LED pin as an output:
      pinMode(LEDPIN, OUTPUT);
      // initialize the sensor pin as an input:
      pinMode(SENSORPIN, INPUT);
      digitalWrite(SENSORPIN, HIGH); // turn on the pullup
    void loop(){
      // read the state of the pushbutton value:
      sensorState = digitalRead(SENSORPIN);
      // check if the sensor beam is broken
      // if it is, the sensorState is LOW:
      if (sensorState == LOW) {
        // turn LED on:
        digitalWrite(LEDPIN, HIGH);
      else {
        // turn LED off:
        digitalWrite(LEDPIN, LOW);
      if (sensorState && !lastState) {
        Serial.println("Unbroken");
      if (!sensorState && lastState) {
        Serial.println("Broken");
      lastState = sensorState;
What I need?
Sensor is atached to the the ending point of tube, where ping pong ball fly out.
  1. When Ball 1 fly out sensor give signal to arduino and servo motor goes to position 1.
  • servoLeft.write(20,255,false);
  1. When Ball 2 fly out sensor give signal to arduino and servo motor goes to position 0.
  • servoLeft.write(0,255,false);
  1. I need this cycle for 6 balls (left rigt, left right, left right) and then pause
  • delay(4000);
  1. And then we go again, this left right drill
I know this is not so hard to do it, but I am not programmer, and I need your help.
Thanks
Is this so simple or to hard to code it. Nobody can help?!!
