Bricked my RP2040 Connect
Hi All,
I somehow have gotten my rp2040 Connect into a bad state. I can add the jumper and plug in USB and see the device (on my Windows 10 PC) as RPI-RP2 however it no longer appears as a COM port. If I attempt to drag either blink.ino.elf.uf2 or PicoMiteV5.07.04.uf2 (MM Basic) to the drive I get an error saying the file already exists and a prompt to overwrite it. If I elect to overwrite, I am shown a prompt saying I need admin privileges. If I continue as admin I am repeatedly asked to retry after the operation fails.
I'm sure there is a way to use Atmel's ICE debugger to reload the original firmware to recover from this. Are there instructions somewhere how to do this? Or is there an easier way? I've tried the IDE and fwuploader but since the device never shows a serial port these can't connect.
Thanks,
Scott
Ref.: unBrick my RP2040 - Google Search
If you have official Arduino RP2040 Connect, then check https://support.arduino.cc/hc/en-us/articles/4404168794514-Nano-RP2040-Connect-not-being-detected-on-USB-port and try each of the suggestions there.
Hi Jazmin,
Here’s the other info you requested.
I’m running Windows 10 pro 21H2 with an AMD threadripper 2950X.
Arduino Mbed OS Nano Boards V3.2.0 (no updates available).
After pressing switch twice, green LED is lit continuously, as it is when the board is first plugged in. No other LEDs light.
Here’s a device manager screenshot with the board plugged in. No serial ports are shown.
As I explained yesterday, the board doesn’t enumerate a COM port, so no software detects it.
If I add the jumper and plug it in, it does appear as RPI-RP2, but here’s what happens when I drag blink.ino.elf.uf2 to drive G:
The file doesn’t appear in file manager immediately.
Here’s the compile/link output with verbose turned on:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Nano RP2040 Connect"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Scott\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Scott\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Scott\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nanorp2040connect -ide-version=10819 -build-path C:\Users\Scott\AppData\Local\Temp\arduino_build_739508 -warnings=none -build-cache C:\Users\Scott\AppData\Local\Temp\arduino_cache_555768 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.imgtool.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\imgtool\1.8.0-arduino.1 -prefs=runtime.tools.imgtool-1.8.0-arduino.1.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\imgtool\1.8.0-arduino.1 -prefs=runtime.tools.openocd.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.dfu-util.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.rp2040tools.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\rp2040tools\1.0.6 -prefs=runtime.tools.rp2040tools-1.0.6.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\rp2040tools\1.0.6 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\bossac\1.9.1-arduino2 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Scott\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Scott\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Scott\Documents\Arduino\libraries -fqbn=arduino:mbed_nano:nanorp2040connect -ide-version=10819 -build-path C:\Users\Scott\AppData\Local\Temp\arduino_build_739508 -warnings=none -build-cache C:\Users\Scott\AppData\Local\Temp\arduino_cache_555768 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.imgtool.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\imgtool\1.8.0-arduino.1 -prefs=runtime.tools.imgtool-1.8.0-arduino.1.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\imgtool\1.8.0-arduino.1 -prefs=runtime.tools.openocd.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.dfu-util.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.dfu-util-0.10.0-arduino1.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\dfu-util\0.10.0-arduino1 -prefs=runtime.tools.rp2040tools.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\rp2040tools\1.0.6 -prefs=runtime.tools.rp2040tools-1.0.6.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\rp2040tools\1.0.6 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\bossac\1.9.1-arduino2 -prefs=runtime.tools.bossac-1.9.1-arduino2.path=C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\bossac\1.9.1-arduino2 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
Using board 'nanorp2040connect' from platform in folder: C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0
Using core 'arduino' from platform in folder: C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0
Detecting libraries used...
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\sketch\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\sketch\Blink.ino.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\sketch\Blink.ino.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT\nina_pins.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\nina_pins.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT\double_tap_usb_boot.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\double_tap_usb_boot.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT\variant.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\variant.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-gcc" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\arm_hal_random.c.o" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\arm_hal_random.c"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-gcc" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\itoa.c.o" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\itoa.c"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\Interrupts.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Interrupts.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\Serial.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Serial.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\random_seed.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\random_seed.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\Tone.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Tone.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\main.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\main.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\abi.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\abi.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\USB\PluggableUSBDevice.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\PluggableUSBDevice.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\USB\USBCDC.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\USBCDC.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\Print.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Print.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\WMath.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\WMath.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\wiring_shift.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_shift.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\pinToIndex.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\pinToIndex.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\wiring_pulse.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_pulse.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\USB\USBSerial.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\USBSerial.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\timer.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\timer.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\wiring_digital.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_digital.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\wiring.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\mbed\platform\cxxsupport\mstd_mutex.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\mbed\platform\cxxsupport\mstd_mutex.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\String.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\String.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\wiring_analog.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_analog.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\IPAddress.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\IPAddress.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\Common.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Common.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\Stream.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Stream.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\api\PluggableUSB.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\PluggableUSB.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/defines.txt" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -MMD -mcpu=cortex-m0plus -DARDUINO=10819 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated" "-IC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino/api/deprecated-avr-comp" "-iprefixC:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino" "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/includes.txt" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\cores\arduino\as_mbed_library\variant.cpp" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\as_mbed_library\variant.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\arm_hal_random.c.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\itoa.c.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Interrupts.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Serial.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\Tone.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\PluggableUSBDevice.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\USBCDC.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\USB\USBSerial.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\WMath.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\abi.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Common.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\IPAddress.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\PluggableUSB.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Print.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\Stream.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\api\String.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\as_mbed_library\variant.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\main.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\mbed\platform\cxxsupport\mstd_mutex.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\pinToIndex.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\random_seed.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\timer.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_analog.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_digital.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_pulse.cpp.o"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\core.a" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\wiring_shift.cpp.o"
Archiving built core (caching) in: C:\Users\Scott\AppData\Local\Temp\arduino_cache_555768\core\core_arduino_mbed_nano_nanorp2040connect_3e4b2d6dd62041ce947f1563a27a4d9d.a
Linking everything together...
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -E -P -x c "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/linker_script.ld" -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/linker_script.ld"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" "-LC:\Users\Scott\AppData\Local\Temp\arduino_build_739508" -Wl,--gc-sections -w -Wl,--as-needed "@C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/ldflags.txt" "-TC:\Users\Scott\AppData\Local\Temp\arduino_build_739508/linker_script.ld" "-Wl,-Map,C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.map" --specs=nosys.specs -o "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.elf" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\sketch\Blink.ino.cpp.o" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\double_tap_usb_boot.cpp.o" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\nina_pins.cpp.o" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508\core\variant.cpp.o" -Wl,--whole-archive "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/core\core.a" "C:\Users\Scott\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.2.0\variants\NANO_RP2040_CONNECT/libs/libmbed.a" -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.elf" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.bin"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.elf" "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.hex"
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\imgtool\1.8.0-arduino.1/imgtool" exit
"C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-size" -A "C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.elf"
Sketch uses 89588 bytes (0%) of program storage space. Maximum is 16777216 bytes.
Global variables use 43448 bytes (16%) of dynamic memory, leaving 226888 bytes for local variables. Maximum is 270336 bytes.
C:\Users\Scott\Documents\ArduinoData\packages\arduino\tools\rp2040tools\1.0.6/rp2040load -v -D C:\Users\Scott\AppData\Local\Temp\arduino_build_739508/Blink.ino.elf
rp2040load 1.0.6 - compiled with go1.16.2
Loading into Flash: [==============================] 100%
Board at COM4 is not available
Tools|Port remains grayed out, and the board’s LED is not blinking. The green LED remains lit.
Here’s the invoice from Amazon:
Thanks,
Scott
dm1
Hi Jazmin,
Although the script says the blink sketch uploaded, it did not! The LED doesn't blink and no COM port appears. There are no unidentified or unknown devices, and no USB errors are reported, just nothing happens.
Nothing has changed. After double tapping the switch the green LED is on steady and no other (LEDs) light.
Scott
I'll make the video this weekend.
Hi Jazmin,
Here's a link to the video: Dropbox - Videos - Simplify your life
As I said before, the sketch doesn't successfully upload, see the video. After removing the jumper, and cycling power or resetting the board, the green LED remains lit, and no other LEDs light. Also, no COM ports enumerate.
Thanks,
Scott
Scott
See above.
Hi Jazmin,
So how does this relate to the RP2040 Pico I have that's doing exactly the same thing? I think there's an underlying problem causing this.
Scott
Hi Jazmin,
Also, is it possible to reprogram the board with its SWI interface with the code it originally shipped with? If so, what programmer do I need and where do I get the code from?
Thanks,
Scott
