Hi everyone ,
this will be my first project after i played around with the Arduinos examples and wonderful projects like the Parola_Lib .
My project is to use a 10'' Jumbo 7-segment Led displays i Build almost 30 years ago based on the Elektor Magazine issue of Jun, 1985, its called the Jumbo Clock.
about the old one :
i don't have the controller board any more but i remember it was using 2 x 7216 Eproms , they were burnt with a code that handle the 7-segment displays work and the flashing colon in the middle and the Temperature negative sign and the degree symbol ,was based on the 50Hz time base from the AC line, some logic math chips , an ADCxxx Analogue/ digital converter chip ,an LM335 Temp sensor and 2 switches to adjust the Time ( Fast ,Slow).
the 7-segment Jumbo displays each use a 74LS248 BCD to 7-segment decoder with a MPSA14 transistors on the output ,current limiting resistors and run on 24V dc.
MY Project :
to use the Arduino ONO or 2560 to drive the Jumbo displays , keeping the same clock / Temperature Functions , but using new approach to the design .
I'm planing to use the DS1307 time base for clock time keeping and use either the DHT11 or LM35 /LM335 for temperature sense (depending on the code complexity), i'm a C++ novice i only did basic and PIC Assembly in the past.
the 74LS248 takes BCD code and decoded to 7-segments so properly have just to read time from the DS1307 and pass it through to the right digit.
my Questions , i have 2 ideas , either go with a direct drive (4-bit per display) and the LT,RBI,Upper Degree Symbol, Negative sign =20 pins + 3 for sensors and 2 for switches (witch i can omit for now because i can set DS1307 and forget about it).
Or Remove the 74LS248 from the displays and use a MAX7219 and Multiplexing the displays.
OR i'm open for any idea will make the project easier , i'm going to be relying on the code blocks from the Arduino libraryes
because of me not knowing C++ i have no problem with Hardware.
please check my attachments i appreciate any help.
