Bts7960 driver with arduino
Note that the motor is 12,000 rpm, what sort of gearbox have you got to lower the speed for drive wheels?
Just slowing the motor will lower the available torque and possibly make the motor at low speed very erratic to control.
The image you provided is low resolution so cannot read any pin names/numbers.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Just measure resistance across the motor terminals
Ok can you check the pdf please
Please wathe these video
They don't mention the stall current.
So better to measure the resistance.
In the specification list
Stall Current is not there.
Measure the resistance.
Ok in that video is correct or not
Motors have gearboxes, do yours?
Gearbox will help with starting and running current.
Higher res image.
What you mean
I guess, it look like it works. Do you trust this guy?
Why do't you measure the resistance?
No but there is no other way
First i am used l298n driver but that heating and no rpm controll so i am searcing that time i get thise video
If you measure the resistance then I can tell you if you can use two motors.
Hi, @ragesh2255
Please post images of the hardware you have.
Can you please post a copy of your circuit with the L298N drive, a picture of a hand drawn circuit in jpg, png?
Ok. How will check just like checking a voltage
Set your meter to resistance and set it to the lowest scale, maybe it says 200.
Disconnect the motor from everything and connect the meter leads to the motor.
Read what the meter displays.
Do you need help making the resistance measurement?
Thanks sir
Tomorow i will check multimeter in our college so then i will post the readings in night 8 pm
No hurry
