Buffer is not working properly!
Hello,
I am using that Buffer as a component for impedance matching before amplifying a signal from an acoustic sensor. The issue is that I wanted to test the component using a power supply to power it (+15v), using the a similar circuit without any resistor or capacitor :
The issue I am facing is I am getting in the output a value that is approximately the same as the power supply value with a constant offset of 0.3v.
I tried to let the input in :
floating position.
Grounding position.
Varying it using the same power supply via the voltage divider.
The output is not tracking the input at all. Does anyone passed via a similar issue before ?
I tried to change it with another Buffer but still getting the same result.
  • Hum, if we could only see some actual images of the wiring.
Hello,
Are you using a symatrical power supply?
+15V on a side, and -15V on the other one?
+1 :slight_smile:
Hello,
No, I am using a regular power supply with + - and ground. Does this work with regular power supply ? I am willing to put this component in a pcb that will be powered using batteries... But still couldn't make it work!
Regards,
Hey,
Thanks for you reply, what else do you want to know? the link for the datasheet was already included in my post...
Furthermore, I am measuring +15v between V+ and V-.
No
You need +/- 15V
Is the output of the sensor bipolar?
For help, you need to provide more information. Please post a link to the data sheet for the acoustic sensor, the amplifier and a schematic of your circuit.
Please explain why you think you need an impedance match.
Cross-post.
Why don't you buy the matching amplifier for that sensor.
The (minimal) sensor data sheet is in the @zaki_HDne's cross post:
The sensor appears to be a rather simple ultrasound piezoelectric transducer and given the microscopic amount of information in the data sheet, is obviously designed to be used in conjunction with the company's other products, not as a DIY component.
Most likely it is sold as a replacement part for the company's inspection and testing systems.
Product blurb:
Nevertheless, acceptance of AE as inspection and testing method was driven by integrity inspection of pressure vessels. Application of AE measurement spread from testing a pressure vessel to corrosion testing of flat bottom storage tanks (above ground storage tanks), leakage testing of pipelines and valves, testing for partial discharge in transformers, and nowadays finds its entrance in structural health monitoring of civil engineering structures.
The idea is to make one that can be more versatile. But first, I will try to make a similar one.
Yeah I think so. But I think I still can make a similar pcb with a buffer and two or three amplification stages...
BUF634 has a gain of ONE
Why do you think you need it?
What are you trying to build?
yeah, that's the point. It has a high input impedance which can be helpful with the sensor impedance. That's why I think I need it.
Here's the schematic:
The + input of almost ALL opamps is high impedance.
Just use your ADA4899 as a unity gain buffer plus another for gain
According to the ADA4899 datasheet, the bigger the impedance the lower is the frequency...
I have to say that I'm not sure what that graphis showing.
They mention below that graph that it's about input impedance vs Frequency... Knowing that the output of the buffer is very low...
