Servo mouth audio triggered star wars
int not jawduino please
int I need a copy and paste code
script got the arduino I have a sampler chip isd1820 so people can record their voice I don't need an audio jack I have jumper wires I don't need a mp3 file I feel like with the right code that's all I need ofcouse I have buttons and pots already
loop please your are my only hope
You understand that the forum isn't a free software factory, right?
We'd be happy to help you with your code.
aw man you can do it easily huh? bro hook it up .....also im trying to figure out how to control a video loop wiht a divider chip and some touch sensors the sooner I can resource the best way to do it the better take me to church bro
Good luck, bro.
@newnumbertwo ,
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
is pinn one for the op loop
input pin is up when the post val is op loop
post amp
this should be a very typical project. A servo moves according to audio val the mats for this would be a computer micro controller a servo and audio source ....people that have done this well don't typically share how they did it online (its normally a "test") so im not trying to expose a trade secret ...I paint portraits of musicians comedians and I thought it would be cool to solder up a sampler chip with the painting so its interactive and talks I also have touch sensors that modify the sample so people can touch the sensors to creat a musical little experience ....sethward from AGT is one of the paintings so its kind of a zany art project ....but this would be like my signature so that's what it is for .....theres a sequencer running with leds .......im also trying to run the touch sensor pad through arduino to Max jitter to change the rate of the video using different divisions .....so any advice to get me closer ...I feel like these two projects are very close to being executed ....this is for music and art sadly that's all im really good at really so please if anyone has time thank you in advance I realize you all have your own projects I just need a little push
What happens when you press and hold the red "REC" button? Do you see the recording LED light up on the board?
I have the isd 1820 chip its not the module the way its set up one the bread board rn is three buttons record, play trigger, play gate, pitch potentiometer theres a loop switch and yes the led lights up when you press record and loop reset ...ive installed a cap and resistors to record incoming audio from a synth or a computer (for gain ) theres also a built in high pass filter to reduce noise level ...you can connect the feedthrough pin to 5v on a Switch and a couple other components to use it as a filter
Write coherently, and intelligibly. Of the nine posts you created, one was deleted due to its trollness, one was a deleted duplicate topic, five were complete rambles, and these last two were difficult to comprehend. State your purpose, clearly. You want audio with your touch-visual? DFplayerMini for the win - DFPlayer Mini Mp3 Player - DFRobot Wiki
Thank you for answering my first question.
Second question: If you record some audio while holding down the "REC" button on the board, can you hear the recording when you press the middle button ("PLAYE").
Also, you wrote:
You're an artist right? Any chance that you could draw (or paint) us a diagram that shows all of those components and how all the wires are connected?
I can put everything in the output pin and the op loop
ive heard of the df player ....im not using mp3 files from a disk tho... seems like there is another way to patch audio to arduino how to get arduino to recognize the audio values
https://bastl-instruments.com/content/6-support/2-tutorials/4-omsynth-project-3/sampler_with_synth.png
That is a working circuit (although there is no Arduino microcontroller in it). What is it that you need help with?
its simple just using the arduilno to measure an analog voltage which is patched into the video playback position in a jitter object
I want to control a servo with the touch sensor pad ....so when there is audio input the painting opens its mouth (servo) when the audio is low the servo "closes"
Can you indicate which of the wires in your circuit diagram above has the voltage that you wish to sample with the Arduino analog-to-digital converter?
