I want to build a plane using an arduino uno i also want it to be rc at first i wanted to use an ir reciver and remote but the range is very limited i dont have a different idea on how to control it otherwise any ideas please i dont have wifi on my arduino
I moved your topic to an appropriate forum category @roishoval .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
For your Arduino-based RC plane, a better solution than IR would be to use radio frequency (RF) communication. Here are a few options that would provide longer range and better control:
1. 433 MHz RF Modules (e.g., FS1000A)
- These modules are easy to use and can provide a decent range of up to 100 meters in open space. You can use the VirtualWire or RadioHead library to communicate between an Arduino on the plane and a remote Arduino with a joystick or other control interface.
2. RYFA433 REYAX Transceiver Module
- The RYFA433 operates in the 390 MHz to 510 MHz ISM band with FSK and GFSK modulation. It has a data rate of 150 kbps and excellent sensitivity (-117dBm), providing long-range communication (up to 500 meters or more, depending on conditions). It’s well-suited and I would personally recommend for RC projects and can handle control signals like throttle, rudder, and ailerons. You would need an RF module on both the plane and the ground controller.
- It communicates over SPI or UART, making integration with the Arduino UNO straightforward.
3. 2.4 GHz Transmitter and Receiver (e.g., NRF24L01)
- These modules offer a longer range (up to 1 km with an external antenna) and higher data rates. The NRF24L01 is commonly used for RC projects because of its reliable performance and ease of integration with Arduino. You would need one module on the plane and another on your RC controller.
- A joystick or potentiometer can be used to control the plane’s movement (throttle, aileron, elevator).
4. LoRa Modules
- If you're aiming for a very long-range solution, LoRa (Long Range Radio) modules are perfect for that. They operate in the sub-GHz range (433 MHz or 915 MHz), and you can get ranges of up to 10 km in open space. They are slower in data transmission compared to the NRF24L01, but excellent for long-distance control.
5. Bluetooth Modules (HC-05 or HC-06)
- Bluetooth provides a short-range alternative (up to 10-50 meters), depending on the module and conditions. You could pair the Arduino with a phone app or another Arduino for control, but the range will still be limited compared to RF.
Components Needed:
- Arduino UNO for the plane.
- RF Module (e.g., RYFA433 or NRF24L01) for communication.
- Servo motors to control the plane’s ailerons, rudder, and elevator.
- Electronic Speed Controller (ESC) to control the motor.
- Brushless DC motor and LiPo battery for propulsion.
- RC Transmitter/Joystick to control the plane from the ground (Arduino-based with RF module for transmission).
Basic Plan:
- RF communication: Use an RF transmitter (like the RYFA433 or NRF24L01) on the ground connected to an Arduino for the controller, and the corresponding RF receiver on the plane.
- Control Interface: On the ground, use a joystick, potentiometer, or switches to control the throttle, elevator, rudder, and ailerons.
- Flight Control: Use servos to move control surfaces and an ESC for the motor throttle.
How many channels on your radio transmitter?
If your using 433Mhz modules, check what the legal duty cycle limits are in your part of the World.
In a lot of places the duty cycle can be 10% or maybe as low as 1%. Only being allowed to transmit on such low duty cycles can make responsive RC control a bit of a challenge.
How much weight can your aircraft carry?
