Does anyone know a good op-amp implementation of a "Valley Detector", which I assume would be what one calls the opposite of a peak detector? I need to find the baseline of a signal so I can reject it. I want to do an op-amp circuit instead of with a DAQ so I can do it in real time.
I'm dealing with DC signals, if that makes a difference. The "valley" is a positive nonzero voltage.
Probably, it's same with peak detector, only negative peaks instead of positive. Schem shown here, you need reverse diodes to make it register negative peaks.
Magician:
Probably, it's same with peak detector, only negative peaks instead of positive. Schem shown here, you need reverse diodes to make it register negative peaks. Precision rectifier - Wikipedia
That won't work. There are no negative peaks. The minimum of the signal is nonzero and positive.
Negative compare to "virtual ground", which is 1/2 of power line for single power OPA circuitry in most cases.
What is the nature of the signal? Have you defined a time constants of detector?
I'm forced to use dual-supply on this circuit.
The nature of the signal is a photodiode, driven by a modulated laser on top of thermal IR.
