Hi, I'm a software developer and I have in mind a huge project (at least for me :P) and I would really appreciate if you could help me keep in the right path.
My idea is to build an alarm system for my motorcycle and a deceleration detector, which will activate the brake light automatically (both using the same arduino).
I've been learning a lot from internet about eletronics but there's so many components and compatibility conditions that I'm a litte worry about the components that I chose, especially the relay and resistors.
(I'm also posting the links from where I'm buying these components in case you want to see more information about it)
=> Motorcycle Battery: YTZ10/FTZ10S 8.6Ah MF
=> Arduino Nano
=> Relay 5v 4 channels:
--> Connects to buzzer and motorcycle lights
--> https://www.electrofun.pt/componentes-eletronicos/modulo-rele-5v-4-canais
=> 8v 1.5A Regulator:
--> connection between 12v battery and arduino
--> https://mauser.pt/catalog/product_info.php?cPath=324_245&products_id=002-1703
=>Resistors 10K:
--> Arduino will turn off all the sensors as soon as it detects that the battery is low.
=> RF controller kit:
--> Arm and disarm the alarm
--> Kit Emissor Receptor Controlo Remoto Wireless RF 12V 10A 433MHz
=> Vibration Sensor:
--> When activated, turns ON the buzzer 1 time (just to warn). If the sensor is activated for 3 times in 5 minutes, it will activate the buzzer permanently.
--> https://mauser.pt/catalog/product_info.php?cPath=1667_2669_2674&products_id=096-6657
=> Accelerometer ADXL 345:
--> Every time the alarm is activated, the arduino saves the current XYZ position. If someone moves the bike and the position changes, it will turn ON the buzzer.
--> While riding, if the accelerometer detects a big deceleration (my motorcycle brakes a lot just with the engine), it will blink the brake light.
--> https://www.electrofun.pt/sensores-arduino/modulo-acelerometro-adxl345-3-eixos-i2cspi
=> Bluetooth HC 06:
--> Activate and deactivate sensors
--> Check current battery level
--> Activates the buzzer
--> https://www.electrofun.pt/comunicacao/modulo-bluetooth-arduino-hc06
Buzzer piezo SYR-08A 120db:
--> https://mauser.pt/catalog/product_info.php?cPath=554_910&products_id=091-0107
I was also thinking of putting a GPS tracker and a GSM SIM800L module to send a message everytime the alarm is activated and to send me the coordinates in case it is stolen, but it would be really difficult because I would need 2 more TX and RX ports, right?
So, what do you think?
Everything seems right to me but I'll really appreciate if you guys could check if it is done properly. I'm just not so sure about the RF 433Mhz connections.
Thank you so much!
