The Transducer has only an "antenna"-cable: one core, and the "protecting" aluminium hull.
I guess the trigger pulse is transmitted though the core, and the echo signal also (alternating)
the protecting hull was connected to ground.
The device is 12 volt, and when measuring on another device, I can see the trigger puls is 12 volt
I would like to try something like the following:
connect the sensor to the Arduino
send trigger signals to the sensor
receive the echo signal
measure the duration and calculate the depth.
Before getting into it too deep I wanted to ask, if anyone can point me into a direction to follow, or give an estimation, if it seems a rather easy, or rather complicated project?
thank you very o the much for your quick answer. Yes, it is a coax cable, thanks also for the clarification.
Yes, an ocilloscope would be perfect, but I don't have one. have used a Multimeter, wich showed very fluctuating 12 or 0 volts. So I guess this was the Puls.
Ok, I understand. In my rather "greenhorn" understanding, I thought, the input to the Transducer would be a simple "HIGH" with 12 volts, wich would then be changed to a sonic frequency in the transducer. If this "ultrasonic frequency" (something like 20.000 kHz) has to be produced by the Arduino, then I guess this project is ended here
If there is any more advice, I would love to hear it, but if everyone agrees to the complexity of this project, this will be a very short thread
Does anyone maybe have a recommendation for a transducer that can be connected to Arduino? I guess it should be driven by more than 5 volts, since in my understanding underwater echo sounders need more power to have sufficient range.
I have tried with this one: Jsn-sr04t, but it is only for application in air, and I did not manage to make it work underwater.
