Burning Bootloader to ATmega8
Hello,
I’m trying to burn a bootloader to an ATmega8A AU 1451 that’s soldered to the PCB of an ESC I want to reprogram. I’ve uploaded the ArduinoISP Sketch to an Arduino Nano (old Bootloader), installed MiniCore and followed the instructions given there.
Here’s my wiring:
I have confirmed the connections from each Arduino Pin to the ATmega8 using a multimeter.
These are my settings:
The legs for the xtal of the ATmega8 are not soldered to the board, so it’s using the internal crystal.
When clicking on “burn Bootloader” I get the following error:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "ATmega8, No bootloader, EEPROM retained, Default, BOD 2.7V, LTO enabled, Internal 8 MHz"
avrdude error: Yikes!  Invalid device signature.
avrdude error: expected signature for ATmega8 is 1E 93 07
        Double check connections and try again, or use -F to override this check.
Error while burning bootloader.
Here's the verbose error:
B:\Anton\Documents\ArduinoData\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude -CB:\Anton\Documents\ArduinoData\packages\MiniCore\hardware\avr\3.0.1/avrdude.conf -v -patmega8 -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0b10100100:m
avrdude: Version 7.2-arduino.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is B:\...\ArduinoData\packages\MiniCore\hardware\avr\3.0.1\avrdude.conf
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude stk500_getsync() warning: attempt 1 of 10: not in sync: resp=0x15
avrdude stk500_getsync() warning: attempt 2 of 10: not in sync: resp=0x15
         AVR Part                      : ATmega8
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                           Block Poll               Page                       Polled
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom                  4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash                  33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           calibration             0     0     0    0 no          4    1      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 version 1.x firmware
avrdude stk500_getparm() error: protocol expects OK byte 0x10 but got 0x14
avrdude stk500_getparm() error: protocol expects sync byte 0x14 but got 0x02
avrdude stk500_getparm() error: protocol expects sync byte 0x14 but got 0x10
         Hardware Version: 49863976
         Firmware Version: 0.2
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude stk500_initialize() error: protocol expects OK byte 0x10 but got 0x01
avrdude main() error: initialization failed, rc=-1
        - double check the connections and try again
        - use -B to set lower the bit clock frequency, e.g. -B 125kHz
        - use -F to override this check
avrdude stk500_disable() error: protocol expects sync byte 0x14 but got 0x10
avrdude done.  Thank you.
Any help would be greatly appreciated, I don’t know how to troubleshoot this.
Interesting. As you can see, there is a communication out of sync. Hard to say why. Still, it can be problem with ISP wire or some other HW problem. Check it again. What about upper wires from red board, are they connected somewhere? Do you have red board schematics?
Try to run the command from CMD line with -vvvv for very detailed log but without any write and erase, it means without -e and all behind.
What brand and model ESC was it?
I have flashed a few in the past with BLHeli firmware and that worked just fine.
Can you trace if they maybe used a low value resistor that ties the reset pin to VCC?
If they have locked the chip by setting the SPIEN or the RSTDISBL fuse bit you will need a HV programmer to unlock it.
The upper wires form the breadboard are not connected to anything. I did try connecting them to power so the ATmega8 gets its own 5V form the regulator on the red board, but that didn’t change anything.
Unfortunately, I don’t have the schematic of the red PCB. This one is similar (and so far all the pins where identical) but definitely uses fewer components: GitHub - NicksonYap/XXD-HW30A-ESC-Schematic: Reverse-engineered schematic of the cheap 30A ESC, XXD HW30A
Can you elaborate on how to get the detailed log? Do you have a link to some instructions or something similar? :sweat_smile:
It’s one of the generic yellow 30A ESCs by no particular brand. They usually show up when you search for ESC and sort by price :smile:
I have also successfully programmed an ESC with BLheli, but did all of that using the BLheli configurator.
I have measured 10k from the ATmega8 reset pin to 5 V and 11k to GND. I tried pulling the pin up or down using a 1k resistor, but to no avail.
Do not connect redundant power. Power is from Arduino as ISP.
Try this from CMD:
B:\Anton\Documents\ArduinoData\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude -CB:\Anton\Documents\ArduinoData\packages\MiniCore\hardware\avr\3.0.1/avrdude.conf -vvvv -patmega8 -cstk500v1 -PCOM3 -b19200
This is the command from log you have posted. I just modified -v to -vvvv and cut the -e and the rest.
Try to check the reset pulse, e.g. with the DMM. It means DC voltage between RESET pin and GND on the target MCU should be 5V and you should see a drop to 0V as the uploading process starts.
Have you actually connected anything to the reset pin of the Atmega8? It is the fourth pin from the left on the top row in your picture. I don't see any wires going to it.
I have the exact HW30A esc, that you referred to the schematic. On mine the reset is connected to nothing. With my TQFP programmer foot I could extract the firmware and eeprom contents without a problem.
Don’t worry, I disconnected the 5 V line when connecting power to the red board :innocent:
This is what happened when I ran the command you provided:
         System wide configuration file is B:\Anton\Documents\ArduinoData\packages\MiniCore\hardware\avr\3.0.1\avrdude.conf
         Using Port                    : COM3
avrdude: send: 0 [30]   [20]
avrdude: recv: . [14]
avrdude: recv: . [10]
         AVR Part                      : ATmega8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: send: A [41] . [80]   [20]
avrdude: recv: . [02]
avrdude: send: A [41] . [81]   [20]
avrdude: recv: . [01]
avrdude: send: A [41] . [82]   [20]
avrdude: recv: . [12]
avrdude: send: A [41] . [98]   [20]
avrdude: recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: send: A [41] . [84]   [20]
avrdude: send: A [41] . [85]   [20]
avrdude: send: A [41] . [86]   [20]
avrdude: send: A [41] . [87]   [20]
avrdude: send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: send: B [42] p [70] . [00] . [00] . [01] . [01] . [01] . [01] . [02] . [ff] . [00] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: send: E [45] . [05] . [04] . [d7] . [c2] . [01]   [20]
avrdude: send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading |                                                    | 0% 0.00 s
avrdude: send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: send: V [56] 0 [30] . [00] . [01] . [00]   [20]
Reading | #################                                  | 33% 0.02 s
avrdude: send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | ################################################## | 100% 0.03 s
avrdude: device signature = 0x000000 (retrying)
avrdude main() [main.c:1409] error: Yikes!  Invalid device signature.
avrdude main() [main.c:1411] error: expected signature for ATmega8 is 1E 93 07
        this check.
avrdude: send: Q [51]   [20]
The reset pin is usually on 4.58 V and falls to 0 V for a short time when trying to burn the bootloader.
I measured a 0 ohm connection from the reset pin of the chip to one of the six exposed pads on the PCB and soldered the green wire to it.
So you successfully reprogrammed the version of the ESC as seen in the Github link, but not the slightly different one I have?
Ok, yours has the programming pads exposed. That's convenient.
Yesterday I was able to program the version as seen in Github with the SimonK/BLheli (tgy.hex) firmware and that worked just fine as long as my servopulses were within the standard range of 1000-2000 us. Then I programmed it back to the original firmware and eeprom content, that I had extracted first.
I did notice however that none of my USBASP programmers could not talk to it, but my USBTinyISP could. I did not look in the schematic if maybe some components were connected to the Miso, Mosi or Sck pins of the AT8, that interfered with the USBASP.
I don't have your version, or maybe I have, but I just opened one of the many 30A el-cheapo ESC's that I have.
There is no response from the target MCU. I would say bad wires or MCU does not start. ISP sketch is working as expected. If the MCU is not dead then definitely must be something with these 6 wires.
It does not seem right to me. It can be a problem. RESET pin is 4th leg from left in upper row on your picture. There is obviously a trace to a resistor, the right one above MCU. I can't read the value. Check it visually if the wire is connected correctly. Also check it with the DMM as the upload starts the DC voltage have to drop visibly from 5V to 0V for a moment.
I can tell that the MCU is not dead because it does its job in the circuit (turns the motor) and makes it beep as soon as power is connected.
I have confirmed with my multimeter that the reset pin of the ATmega8 is pulled low when trying to burn the bootloader. The pin is connected to a 10k pull up resistor (the one you saw in my picture). The trace to the reset pad I soldered the green wire to comes up from underneath the chip, so I think that’s why we can’t see the connection to the chips reset pin.
Could you tell form the response to the command I send if the reset pin or ISP programming have been disabled?
Could I connect a transistor to pin 10 of the Arduino so that instead of resetting the ATmega8 it cuts its power and resets that way (in case the reset pin is disabled)?
No. There are no such details.
Yes, definitely. Worth the shot. Post the output log.
Maybe ATmega will need longer time to start. I am not sure now if it is significant for this case, but try it first. It is good idea anyway. Kudos!
However, it can be SPI disabled. In this case only paralel programming would help.
You can test if reset is disabled by connecting reset to ground and see if your ESC still works. The fact that they added a 10K resistor between RST and VCC would suggest reset is not disabled.
Unless the HW folks designed for a non-locked MCU and they decided to lock it afterwards.
This makes sense.
Just thought of this.
You have programming pads on the PCB, which means it is manufactured with a unprogrammed AT8 and then programmed afterwards via the programming pads (using pogo pins).
For programming afterwards, even if it is only once, you need a working RST pin. After/during programming they could set the lockbits to disable SPIEN and/or RST.
I finally got around to trying this, but I don’t have good news:
The reset pin of the ATmega8 appears to be disabled. I connected it to ground, but the ESC keeps on happily beeping as if nothing happened.
The cut-power-using-transistors-as-a-reset-idea also didn’t work. Disconnecting the GND of the ATmega8 using an NPN transistor didn’t do much. Using a circuit with a PNP transistor to disconnect 5 V did turn off the ATmega8 using the pin 10 reset pin, but I still couldn’t burn the bootloader.
         Using Port                    : COM3
         AVR Part                      : ATmega8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
        this check.
So SPI is probably also disabled, and I’m not really willing to get into high voltage parallel programming, so I’m kind of out of options now. Seems like this MCU will keep its code.
Thank you very much for your help though!
