Button box arduino pro micro
Ola pessoal estou precisando do auxilio de vcs, montei uma button box com arduino pro micro segui esse tutorial https://www.youtube.com/watch?v=Z7Sc4MJ8RPM&list=PLpSGtBgUdLZNo-muVzgPAjDODN4qjq2Rw os botoes funcionam perfeitamente no controlador de jogos, porem no ets as chaves alavancas nao funcionam como on off , elas ligam normal, porem pra desligar eu preciso desligar e ligar pra madar o pulso, o codigo que usei e esse `//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4},
{5,6,7,8,9},
{10,11,12,13,14},
{15,16,17,18,19},
{20,21,22,23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0,1,24,25,0},
{2,3,26,27,0},
{4,5,28,29,0},
{6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
rotary_init();}
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key[i].stateChanged )
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
pinMode(rotaries[i].pin1, INPUT);
pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotaries[i].pin1, HIGH);
digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
if (result == DIR_CW) {
Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
esse ai e o codigo dai descobri esse outro mas nao consigo mesclar `#include "Keyboard.h" //INCLUSÃO DA BIBLIOTECA KEYBOARD
#include "RBD_Button.h" //INCLUSÃO DA BIBLIOTECA RBD BUTTON
RBD::Button pinoReedSuperior(2); //PINO DIGITAL UTILIZADO PELO REED SWITCH SUPERIOR
RBD::Button pinoReedInferior(3); //PINO DIGITAL UTILIZADO PELO REED SWITCH INFERIOR
char teclaFreioDeMao = ' '; //CARACTERE CONFIGURADO NO JOGO (TROCAR PARA O CARACTERE QUE VOCÊ USA NO JOGO PARA ESTE COMANDO)
byte controle = 0; //VARIÁVEL DE CONTROLE
pinoReedSuperior.setDebounceTimeout(50); //DEFINE O TEMPO MÁXIMO DE DEBOUNCE DO PINO
pinoReedInferior.setDebounceTimeout(50); //DEFINE O TEMPO MÁXIMO DE DEBOUNCE DO PINO
Keyboard.begin(); //INICIALIZA A BIBLIOTECA
if((pinoReedSuperior.onReleased()) && (controle == 1)){ //SE pinoReedSuperior FOR SOLTO E controle FOR IGUAL A 1, FAZ
  Keyboard.write(teclaFreioDeMao); //DIGITA O CARACTERE REFERENTE AO COMANDO
if((pinoReedInferior.onReleased()) && (controle == 1)){ //SE pinoReedInferior FOR SOLTO E controle FOR IGUAL A 1, FAZ
//BLOCO EXECUTADO SOMENTE UMA VEZ
if(controle == 0){ //SE CONTROLE FOR IGUAL A 0, FAZ
controle = 1; //VARIÁVEL RECEBE 1
estou usando no modo matriz e as chaves alavancas esta na porta A3 PINO 14, A3 PINO 16 E A3 PINO 10, da pra mesclar esses codigos, alguem pode fazer por favor
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help
