Hello, can someone help me make a buttonbox for a computer using Arduino pro micro. I just want it to work with a gamepad and not a keyboard. Can you send me the code and instructions for connecting to Arduino Pro Micro?
Welcome to the forum
Your topic has been moved to the Project Guidance category of the forum as it does not relate directly to IDE version 1.x
The forum works best if you try to do the work yourself and come back for help with anything that causes a problem. It is not a free code writing service
If, however, you are willing to pay for help, then your topic can be moved to a forum category where you may find someone willing to write the code for you at a price
What is your general electronics, programming and Arduino experience, if any ?
I'm constantly looking for a solution to make the button work as a gamepad and not as a keyboard
I'm from Poland and it's much harder for me to find something. so if anyone knows how to do it and can help me, thank you ![]()
and I have one more question, what could it be if I start the game and it doesn't find Arduino and there is no response on the key. however, Arduino works normally when I connect it to another USB device, it searches for Arduino normally and works normally. What can be?
you're right, I did everything as in this video https://www.youtube.com/watch?v=Z7Sc4MJ8RPM&t=1s
arduino settings
connection diagram:
: A3 A2 A1 A1 15 14 - ....................................................
- 16 : 0 1 2 3 4 5 I
- 10 : 6 7 8 9 10 11
- 9 : 12 13 14 15 16 17
- 8 : 18 19 20 21 22 23
- 7 : 24 25 26 27 28 29
- 6 : 30 31 32 33 34 35
> /********** 36 Buttons and 3 Rotary Encoders button box by BaldEagle gaming **********/
> *This code is for creating a button box with 36 buttons with 3 rotaries and 0 axis
> *This code is for Arduino pro micro
> *The table below is showing how the buttons are connected to the board (pin)
> *A3, A2, A1, A0, 15 and 14 Are the Row Pins for the Keypad 16 and 10-6 are the Column Pins
> *the buttons are connected to each others according to this table
> * : A3 A2 A1 A1 15 14
> * 16 : 0 1 2 3 4 5 I
> * 10 : 6 7 8 9 10 11
> * 9 : 12 13 14 15 16 17
> * 8 : 18 19 20 21 22 23
> * 7 : 24 25 26 27 28 29
> * 6 : 30 31 32 33 34 35
> * Pin 0, 1, 2, 3, 4, and 5 plus the GND are used for rotaries
> //Including libraries and define variables and give a constant value name
> #include <Keypad.h> //#include is used to include libraries from outside the code.
> #include <Joystick.h>
> #define enablePullUps //#define is used to give a name to a constant value.
> //or to define a new variable
> const byte numOfRotaries = 3; //creating variables to define number of rotary encoders
> //Creating an array with pins that are used
> // for more info: 21 = A3, 20 = A2, 19 = A1, 18 = A0 ....
> byte colPins[] = {21,20,19,18,15,14};
> byte rowPins[] = {16,10,9,8,7,6};
> //define size of array
> const int numOfColumns = sizeof(colPins)/sizeof(colPins[0]);
> const int numOfRows = sizeof(rowPins)/sizeof(rowPins[0]);
> // Creating a 2D array that contains the buttons and also symboling them
> byte buttons[numOfRows][numOfColumns] = {
> {0,1,2,3,4,5},
> {6,7,8,9,10,11},
> {12,13,14,15,16,17},
> {18,19,20,21,22,23},
> {24,25,26,27,28,29},
> {30,31,32,33,34,35},
> //Inislize new keypad class
> Keypad ButtonBox = Keypad( makeKeymap(buttons),
> rowPins, colPins, numOfRows, numOfColumns);
> //create and define the joystick
> Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID, JOYSTICK_TYPE_JOYSTICK,
> 42, 0, // 36 atsButtons, 3x2 rotary encoder (each rotary is count as 2 buttons
> //(clockwise (turn right) and counterclockwise (turn left)), 0 hat switch,
> false, false, false, // no X axis, Y axis, and/or Z axis
> false, false, false, // no Rx, Ry, Rz
> false, false, // no rudder and/or throttle
> false, false, false); // no accelerator, break, and/or steering
> //creating structure (A structure can contain variables, methods, static constructor, ...)
> struct rotariesStruct {
> byte pin1; //define pins and create 3 variabes
> byte pin2;
> int cClockWise;
> int clockWise;
> volatile unsigned char state;
> rotariesStruct rotariesEncoders[numOfRotaries] {
> //this will create 3 rotaries
> {0,1,36,37,0}, //pin 0 and 1 are connected to button 36, 37 (rotary)
> {2,3,38,39,0},
> {4,5,40,41,0},
> //rotary table
> #define DIR_CCW 0x10 //DIR = Directory
> #define DIR_CW 0x20 //ccw = counter clockwise CW = clockwise
> #define R_START 0x0 //R_start = rotary start
> #ifdef HALF_STEP
> //use half step
> #define R_CCW_BEGIN 0x1
> #define R_CW_BEGIN 0x2
> #define R_START_M 0x3
> #define R_CW_BEGIN_M 0x4
> #define R_CCW_BEGIN_M 0x5
> const unsigned char rotaryTable[6][4] = { //[6][4] mean 6 rows and 4 columns
> // R_START (00)
> {R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
> // R_CCW_BEGIN
> {R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
> // R_CW_BEGIN
> {R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
> // R_START_M (11)
> {R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
> // R_CW_BEGIN_M
> {R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
> // R_CCW_BEGIN_M
> {R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
> #else
> //use full step
> #define R_CW_FINAL 0x1
> #define R_CW_NEXT 0x3
> #define R_CCW_BEGIN 0x4
> #define R_CCW_FINAL 0x5
> #define R_CCW_NEXT 0x6
> const unsigned char rotaryTable[7][4] = { //7*4
> // R_START
> {R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
> // R_CW_FINAL
> {R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
> // R_CW_BEGIN
> {R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
> // R_CW_NEXT
> {R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
> // R_CCW_BEGIN
> {R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
> // R_CCW_FINAL
> {R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
> // R_CCW_NEXT
> {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
> #endif
> void setup() { //setup() is a method called when the program start, and create the variabes and
> //pin mode......
> Joystick.begin();
> initializeRotaryEncoders();
> void loop() { //loop() is a method that run for ever
> CheckingButtons(); //this mean that these 2 methods will run for ever
> CheckingRotaryEncoder();
> //CheckingButtons() function will check the state of the buttons
> void CheckingButtons() {
> if (ButtonBox.getKeys()){
> for (int i=0; i<LIST_MAX; i++) { //LIST_MAX is a variabe created in keypad.ccp and keypad.h
> if ( ButtonBox.key[i].stateChanged ) { //this mean if the button has been pressed/hold or released
> switch (ButtonBox.key[i].kstate) {
> case PRESSED: //if the button is pressed and/or hold
> case HOLD:
> Joystick.setButton(ButtonBox.key[i].kchar, 1); //value will be set to 1 = ON in binary
> break;
> case RELEASED: //if the button is idle or released
> case IDLE:
> Joystick.setButton(ButtonBox.key[i].kchar, 0); //value will set to 0 = OFF in binary
> break;
> void initializeRotaryEncoders() { //create and initial rotary
> for (int i=0;i<numOfRotaries;i++) {
> pinMode(rotariesEncoders[i].pin1, INPUT); //set pins to input
> pinMode(rotariesEncoders[i].pin2, INPUT);
> #ifdef enablePullUps
> digitalWrite(rotariesEncoders[i].pin1, HIGH); //set pins value to high
> digitalWrite(rotariesEncoders[i].pin2, HIGH);
> #endif
> //Create and check pin state
> unsigned char rotaryProcess(int i) {
> unsigned char pinState = (digitalRead(rotariesEncoders[i].pin2) << 1)
> | digitalRead(rotariesEncoders[i].pin1); //get the pins state
> rotariesEncoders[i].state = rotaryTable[rotariesEncoders[i].state //determine a new state
> & 0xf][pinState];
> return (rotariesEncoders[i].state & 0x30); //return the created event
> //check all rotaries encoder
> void CheckingRotaryEncoder() {
> unsigned char result = rotaryProcess(i);
> if (result == DIR_CCW) { //if the rotary has been turned to left
> Joystick.setButton(rotariesEncoders[i].cClockWise, 1); //value will be set to 1
> delay(250); //waiting 250ms = 1/4 second before set the value to 0
> Joystick.setButton(rotariesEncoders[i].cClockWise, 0);
> if (result == DIR_CW) { //if the rotary is turned to the right
> Joystick.setButton(rotariesEncoders[i].clockWise, 1);
> delay(250);
> Joystick.setButton(rotariesEncoders[i].clockWise, 0);
the game searches for Arduino normally, but I cannot assign the keys
this changes when I connect another USB controller and use the button, then the Arduino starts working normally and assigning buttons
I described my problem well, so I don't know what you're talking about... I'm from Poland, so I have to put every message into the translator and then he explains it all to me, it's not that simple... I described my problem as you wanted and you still have a problem to me :]
