I have obtained very good support from ZOOMKAT but i'm not able to do this stupid thing by myself, i've tried and searched the web but can't figure out ....maybe im just tired!
I was trying to convert in button style the following :
The below code has some buttons. The link buttons work ok in IE, but the regular type of buttons seem to have IE waiting on something. Seems not to be a problem in firefox.
Edit, the below kink might be what you need
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat\r\n\r\n");
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
// For simple testing, pin 5, 6, 7, and 8 are used in buttons
// DIY buttons
client.println("<a href='/?on2' target='inlineframe'>ON</a>");
client.println("<a href='/?off3' target='inlineframe'>OFF</a>");
client.println(" <a href='/?off3579' target='inlineframe'>ALL OFF</a>
// mousedown buttons
client.println("<input type=button value=ON onmousedown=location.href='/?on4' target='inlineframe'>");
client.println("<input type=button value=OFF onmousedown=location.href='/?off5' target='inlineframe'>");
client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579' target='inlineframe'>
// mousedown radio buttons
client.println("<input type=radio onmousedown=location.href='/?on6' target='inlineframe'>ON</>");
client.println("<input type=radio onmousedown=location.href='/?off7' target='inlineframe'>OFF</>");
client.println(" <input type=radio onmousedown=location.href='/?off3579' target='inlineframe'>ALL OFF</>
// custom buttons
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8' target='inlineframe'>");
client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9' target='inlineframe'>");
client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579' target='inlineframe'>");
client.println("<IFRAME name=inlineframe style='display:none'>");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
but the effect is different.
In the first case, when it's a plain text link with <a href i get the effect in the IFRAME
In the second case i get the effect on the main page and the url changes to http://192.168.1.20/datastart
That's not right cause it has to target to the IFRAME and not to the main page.
