So a general overview of what I am trying to currently accomplish: I'm trying to use a button matrix for the "keyboard" part of the synth. In this example, it technically makes it a usb midi controller. With this, I can send MIDI notes via usb to a DAW or something. This works fine but it's not quite what I want to do. Instead of sending midi over usb to my computer, I want my corresponding button to send a frequency (or MIDI note, or note name, etc) to a function that accepts the frequency to do all the synth oscillator stuff.
#include <config.h>
#include <Control_Surface.h>
#include <ResponsiveAnalogRead.h>
// Instantiate a MIDI over USB interface.
USBMIDI_Interface midi;
const int maxTransposition = 4;
const int minTransposition = -1 * maxTransposition;
const int transpositionSemitones = 12;
Transposer<minTransposition, maxTransposition>transposer(transpositionSemitones);
//keyboard notes section
const AddressMatrix<2, 14> noteAddresses = {{
{1, 54, 56, 58, 1, 61, 63, 1, 66, 68, 70, 1, 73, 75},
{53, 55, 57, 59, 60, 62, 64, 65, 67, 69, 71, 72, 74, 76},
Bankable::NoteButtonMatrix<2, 14> noteButtonMatrix = {
transposer,
{ROW_3, ROW_4}, // row pins
{COL_0, COL_1, COL_2, COL_3, COL_4, COL_5, COL_6, COL_7, COL_8, COL_9, COL_10, COL_11, COL_12, COL_13}, // column pins
noteAddresses, // address matrix
CHANNEL_1, // channel and cable number
//top row buttons section
const AddressMatrix<1,11> presetAddresses = {{
{59, 60, 62, 64, 65, 67, 69, 71, 72, 74, 76}
Bankable::NoteButtonMatrix<1, 11> presetButtonMatrix = {
transposer,
{ROW_2}, // row pins
{COL_3, COL_4, COL_5, COL_6, COL_7, COL_8, COL_9, COL_10, COL_11, COL_12, COL_13}, // column pins
presetAddresses, // address matrix
Control_Surface.begin(); // Initialize Control Surface
pinMode(LED_BUILTIN, OUTPUT);
Control_Surface.loop(); // Update the Control Surface
Serial.print("noteButtonMatrix");
digitalWrite(LED_BUILTIN, HIGH);
//delay(20);
In this example below I am trying to figure out how to accomplish what I said above with print statements to the console. The issue with this code is that sometimes if I press certain buttons, it prints two statements as if I have multiple buttons pressed. If I press the button 'Q', the console shows I have Q and 3 pressed. It should ONLY be Q. I can't seem to figure out why the above example worked fine and I could have all my figures on the keyboard with no issue, but when trying to send it to a print statement, it acts all wonky lol
#include <Arduino.h>
#include <unordered_set>
const int numRows = 3;
const int numCols = 14;
const int rowPins[numRows] = {29, 30, 31};
const int colPins[numCols] = {32, 0, 1, 9, 5, 4, 3, 2, 14, 24, 25, 26, 27, 28};
const char buttonChars[numRows][numCols] = {
{'\0', '\0', '\0', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N'},
{'\0', 'P', 'Q', 'R', '\0', 'T', 'U', '\0', 'W', 'X', 'Y', '\0', '!', '?'},
{'1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '-', '+', '*', '/'}
std::unordered_set<char> pressedButtons;
for (int i = 0; i < numRows; i++) {
pinMode(rowPins[i], OUTPUT);
digitalWrite(rowPins[i], HIGH);
for (int j = 0; j < numCols; j++) {
pinMode(colPins[j], INPUT_PULLUP);
void scanMatrix() {
pressedButtons.clear(); // Clear the set before scanning
digitalWrite(rowPins[i], LOW);
if (digitalRead(colPins[j]) == LOW) {
char pressedChar = buttonChars[i][j];
if (pressedChar != '\0') {
pressedButtons.insert(pressedChar);
if (!pressedButtons.empty()) {
Serial.print("Pressed buttons: ");
for (char button : pressedButtons) {
Serial.print(button);
Serial.print(" ");
Serial.println("No buttons pressed");
scanMatrix();
delay(100);
Here is my schematic of my matrix as well:
