Button Not Working?
I'm working on a little "experiment" where if i were to press a button, the servo would spin 180 degrees, and if you pressed the button again, it would spin 180 degrees back. The button part seems to not be working although i'm not getting any errors.
#include <Servo.h>
Servo servo;
int buttonPin = 8;
int buttonValue = 0;
int buttonState = 0;
  servo.attach(7);
  servo.write(160);
  pinMode(buttonPin, INPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    buttonValue++;
  if (buttonValue = 1) {
    servo.write(0);
  if (buttonValue = 2) {
    buttonValue = 0;
  if (buttonValue = 0) {
    servo.write(160);
Also, how i set up the wiring:
Diagram
The Button, I'm using that as a button and i couldn't find a good way to represent it here, so i used a potentiometer in the diagram :confused:
And finally, my servo keeps vibrating as well as heating up quite quick, should i be worried?
if (buttonState = 1) {oops
Wrong variable, wrong operator.
Sorry i didn't upload the correct code, and google closed on me
Ok,right variable, wrong operator.
AWOL:
What does that mean exactly , i've only been programming arduino for about a month.
But in that time you've seen the difference between an assignment and a comparison.
AWOL:
I'm a bit confuzed, and sorry if i'm being rude and/or pushy, but what exactly did i do wrong?
if (buttonValue = 1) You wrote three assignments when you wanted three comparisons.
AWOL:
ok thank you, that triggered a memory telling me to add another "=" to each if statement, it doesnt do what i want sort of, but when i;m not pressing the button, it jiggles vigorously, and if i hold the button it stops.
#include <Servo.h>
Servo servo;
int buttonPin = 8;
  servo.attach(7);
  servo.write(160);
    buttonValue++;
  if (buttonValue == 1) {
    delay(20);
    servo.write(0);
    delay(20);
  if (buttonValue == 2) {
    buttonValue = 0;
  if (buttonValue == 0) {
    delay(20);
    servo.write(160);
    delay(20);
Most likely, then, your switch is not wired correctly. How IS it wired?
PaulS:
no that problem has been solved, the issue now is the vigorous shaking of the servo when the button isn't being pushed down.
How? Your diagram does not show a resistor, and you aren't using the internal pullup resistor.
If the button isn't pushed then digitalRead() will show HIGH.
So the buttonValue gets incremented. Let's say it starts off at 0, it gets to 1 and the servo tries to drive to zero.
The next time around the loop, the pin is still HIGH so buttonValue becomes 2. That's then quickly corrected back to 0. The last if() statement sees this and tries to drive the servo to 160.
..repeat forever.
One quick way to fix this would be to move the reset-to-zero after the check-for-zero. Re-order the if() statements so they are looking for 0, 1, 2 in that order.
@PaulS - check the diagram for the button he's using. (Link in 1st post). There's a 10K pullup.
doosteep:
...And that's the biggest reason I hate F**ing diagrams. Don't show components you don't have (or don't intend to buy.)
    buttonValue++;
...Particularly since the "example code" which comes with the button specifically calls for a pulldown resistor!
MorganS:
..repeat forever.
The 10k is just to represent the button as iit isn't in fritzing
You are missing the point. There is a 10K pullup resistor built into the button module. It is like running the pin in INPUT_PULLUP mode. The digitalRead() of the button will be HIGH when it is not pressed, and LOW when it is pressed.
thank you all, the problem has been solved.
#include <Servo.h>
Servo servo;
int buttonPin = 8;
servo.attach(7);
servo.write(160);
if (buttonState == LOW) {
buttonValue++;
delay(20);
servo.write(160);
delay(20);
servo.write(0);
buttonValue = 0;
delay(20);
servo.write(160);
