Button on midi controller keeps hanging/ stops working
Hi everyone,
I am brand new to arduino and quite frankly have no clue what im doing.
Over this last week I have built a midi controller with 16 buttons, 3 potentiometers and a screen.
All seemed to be well, but for some reason the second button in the layout (using pin 3) when either pressed multiple times or when other buttons are pressed and then that button is pressed, stops working entirely and in my DAW (Abelton) the thing I have pressed stay iluminated like its being pressed and not let go, but still all the other buttons work.
There must be something stupid I must be missing here, any and all help is greatly appreciated.
#define ATMEGA32U4 1
#define USING_BUTTONS 1
#define USING_POTENTIOMETERS 1
#ifdef ATMEGA328
#include <MIDI.h>
#elif ATMEGA32U4
#include "MIDIUSB.h"
#endif
#ifdef USING_POTENTIOMETERS
#include <ResponsiveAnalogRead.h>
#endif
#ifdef USING_BUTTONS
const int N_BUTTONS = 16;
const int BUTTON_ARDUINO_PIN[16] = {A5, A4, A3, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1};
int buttonCState[N_BUTTONS] = {};
int buttonPState[N_BUTTONS] = {};
byte pin13index = 12;
unsigned long lastDebounceTime[N_BUTTONS] = { 0 };
unsigned long debounceDelay = 50;
#endif
const int N_POTS = 3;
const int POT_ARDUINO_PIN[3] = {A0, A1, A2};
int potCState[N_POTS] = { 0 };
int potPState[N_POTS] = { 0 };
int potVar = 0;
int midiCState[N_POTS] = { 0 };
int midiPState[N_POTS] = { 0 };
const int TIMEOUT = 300;
const int varThreshold = 20;
boolean potMoving = true;
unsigned long PTime[N_POTS] = { 0 };
unsigned long timer[N_POTS] = { 0 };
int reading = 0;
float snapMultiplier = 0.01;
ResponsiveAnalogRead responsivePot[N_POTS] = {};
int potMin = 10;
int potMax = 1023;
#endif
byte midiCh = 0;
byte note = 36;
byte cc = 1;
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SSD1306_I2C_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  for (int i = 0; i < N_BUTTONS; i++) {
    pinMode(BUTTON_ARDUINO_PIN[i], INPUT_PULLUP);
#ifdef pin13
  pinMode(BUTTON_ARDUINO_PIN[pin13index], INPUT);
#endif
#endif
  for (int i = 0; i < N_POTS; i++) {
    responsivePot[i] = ResponsiveAnalogRead(0, true, snapMultiplier);
    responsivePot[i].setAnalogResolution(1023);
#endif
  if (!display.begin(SSD1306_I2C_ADDRESS, OLED_RESET)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.clearDisplay();
  display.setTextSize(2);
  display.setCursor(0, 5);
  display.println("CAMDEN");
  display.setCursor(0, 18);
  display.println("TOWN");
  display.display();
  buttons();
#endif
  potentiometers();
#endif
void buttons() {
    buttonCState[i] = digitalRead(BUTTON_ARDUINO_PIN[i]);
#ifdef pin13
    if (i == pin13index) {
      buttonCState[i] = !buttonCState[i];
#endif
    if ((millis() - lastDebounceTime[i]) > debounceDelay) {
      if (buttonPState[i] != buttonCState[i]) {
        lastDebounceTime[i] = millis();
        if (buttonCState[i] == LOW) {
#ifdef ATMEGA328
          MIDI.sendNoteOn(note + i, 127, midiCh);
#elif ATMEGA32U4
          noteOn(midiCh, note + i, 127);
          MidiUSB.flush();
#elif TEENSY
          usbMIDI.sendNoteOn(note + i, 127, midiCh);
#elif DEBUG
          Serial.print(i);
          Serial.println(": button on");
#endif
#ifdef ATMEGA328
          MIDI.sendNoteOn(note + i, 0, midiCh);
#elif ATMEGA32U4
          noteOn(midiCh, note + i, 0);
          MidiUSB.flush();
#elif TEENSY
          usbMIDI.sendNoteOn(note + i, 0, midiCh);
#elif DEBUG
          Serial.print(i);
          Serial.println(": button off");
#endif
        buttonPState[i] = buttonCState[i];
#endif
void potentiometers() {
    reading = analogRead(POT_ARDUINO_PIN[i]);
    responsivePot[i].update(reading);
    potCState[i] = responsivePot[i].getValue();
    potCState[i] = analogRead(POT_ARDUINO_PIN[i]);
    midiCState[i] = map(potCState[i], potMin, potMax, 0, 127);
    if (midiCState[i] < 0) {
      midiCState[i] = 0;
    if (midiCState[i] > 127) {
      midiCState[i] = 0;
    potVar = abs(potCState[i] - potPState[i]);
    if (potVar > varThreshold) {
      PTime[i] = millis();
    timer[i] = millis() - PTime[i];
    if (timer[i] < TIMEOUT) {
      potMoving = true;
      potMoving = false;
    if (potMoving == true) {
      if (midiPState[i] != midiCState[i]) {
#ifdef ATMEGA328
        MIDI.sendControlChange(cc + i, midiCState[i], midiCh);
#elif ATMEGA32U4
        controlChange(midiCh, cc + i, midiCState[i]);
        MidiUSB.flush();
#elif TEENSY
        usbMIDI.sendControlChange(cc + i, midiCState[i], midiCh);
#elif DEBUG
        Serial.print("Pot: ");
        Serial.print(i);
        Serial.print(" ");
        Serial.println(midiCState[i]);
#endif
        potPState[i] = potCState[i];
        midiPState[i] = midiCState[i];
#endif
#ifdef ATMEGA32U4
void noteOn(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOn = { 0x09, 0x90 | channel, pitch, velocity };
  MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOff = { 0x08, 0x80 | channel, pitch, velocity };
  MidiUSB.sendMIDI(noteOff);
void controlChange(byte channel, byte control, byte value) {
  midiEventPacket_t event = { 0x0B, 0xB0 | channel, control, value };
  MidiUSB.sendMIDI(event);
#endif
Remove the text of your question from the code block.
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
