Hello everyone!
I've recently started a project with an Arduino Uno, I'm making a midi controller.
The idea is to send serial data and use a software (Hairless MIDI to Serial Bridge) to convert serial to midi, then map it with Ableton/Traktor or any other software.
I started with this tutorial, which works great for me, I managed to make a controller with potentiometers, but I'm struggling with buttons now.
No matter what I do, the button status stays the same and I get a repeated command, which makes a constant stuttering button.
Here's the full code:
int val0;
int lastVal0;
int buttonState0;
int lastButtonState0;
//Potentiometer on А0
val0 = analogRead(0) / 8;
if (val0 != lastVal0)
MIDImessage(176, 1, val0);
lastVal0 = val0;
//Button on D8
buttonState0 = digitalRead(8);
if (buttonState0 != lastButtonState0)
MIDImessage(144, 69, buttonState0); //144 - Note On, 69 - A4 note, 127 - a pressed button
lastButtonState0 = buttonState0;
delay(10);
void MIDImessage(byte message, byte control, byte value)
Serial.write(message);
Serial.write(control);
Serial.write(value);
The problem is the code for button between the slashes.
What I want is a simple button that sends a A4 note on a press, then wait for another time I press it.
I'm also not using any libraries, I figured there must be an easy way to avoid it since the potentiometers work fine.
What am I missing here? Any help will be appreciated, thanks in advance!
