I don't quite understand this code for the buzzer. For example, I don't understand the while loop. While(1)?? While what is 1? delay? it can't be delay because I changed delays value to various different things and it still outputs a frequency. Also, the unsigned char "j" I don't see being used anywhere in the program. Help please! Thanks!
int buzzer = 12;//the pin of the active buzzer
pinMode(buzzer,OUTPUT);//initialize the buzzer pin as an output
unsigned char i,j;
while(1)
//output an frequency
for(i=0;i<50;i++)
digitalWrite(buzzer,HIGH);
delay(1);//wait for 1ms
digitalWrite(buzzer,LOW);
//output another frequency
for(i=0;i<100;i++)
delay(2);//wait for 2ms
It's there because some idiot didn't realize that loop() looped.
When you have a statement like while (i > 14), the comparison of i to 14 yields either true (i is greater than 14) or false (i is 13 or less). You could, therefore do
bool bigger = i > 14;
while(bigger)
So, a single value in the parentheses is not unusual. In this case, 1 is true, so the while statement will run until 1 is false. Since 1 will never be false, the loop will run forever.
Not the same frequency, though, or you have something wired wrong.
Oh no, the world will now come to an end. Yeah, it's stupid, but don't panic over it. There are other things wrong with that program that are more important.
Scotchdew:
unsigned char i,j;
while(1)
for(i=0;i<50;i++)
for(i=0;i<100;i++)
Use the </> Button to wrap the proper CODES around your sketch.
The "While(1);" means Loop Forever
Correct, it is redundant.
Correct, variable "j" is not used.
Did you try changing the "DELAY(1)" and "DELAY(2)" function calls
to "DELAY(10)" and "DELAY(20)" ?
Do you have a BUZZER connected to Pin 12?
A Buzzer has its own "frequency".
This code just turns that Buzzer On/Off per the DELAY(#) intervals.
lol PaulS thanks for the refreshing attitude in your reply (not being sarcastic :P). Also, thanks for the speedy reply guys. I really appreciate it. I was sitting, looking at this code (i'm new to programming obviously) and thinking it wasn't making any sense. Glad to know it's not just me.
mrsummitville I did change the frequency to a 10, 20, even in the thousands if I remember correctly (sounded like a smoke alarm).
