C# Arduino serial communication Serial.Read() dont enought
I have been reading about image processing data using C#. I need to send to Arduino object coordinates. I sent data about x coordinate with the code I wrote below, but I still could not send y coordinates, because I don't know how Arduino will separate x and y coordinates. Is there a method to send data from 2 different channels?
if (serialok == true) {
  int second =0;
  int offset=300;
  second = offset - Math.Abs(objectX);
  map =(float) 0.85 * second;
  buffer[0] = (byte)Math.Abs((int)map);
  serialPort1.Write(buffer, 0, 1);
This is how I read the above code from Arduino.
if(Serial.available()>0) {
  inbyte=Serial.read();
servo1.write(map(inbyte,0,255,0,180));
delay(15);
I made some improvements in the code on C#
int offset2 = 300;
 second2 = offset2 - Math.Abs(objectY);
 map2 = (float)0.85 * second2;
buffer2[0] = (byte)Math.Abs((int)map2);
//serialPort1.Write(buffer2, 0, 1);
string veri = buffer[0] + "#" + buffer2[0];
serialPort1.Write(veri);
 Console.WriteLine(veri);
I'm trying to send 2 strings by combining 2 data with sing of "#"
how can I seperate in arduino for incoming string value , I have to seperate before and after the sign "#" and write servo.write
I realy need to help because I can not think anymore.everything is mixed.
Have a look at Robin2's serial handling tutorial thread.
Thank you very much for your reply , I looked second and 4. examples but I could not set it for myself .While arduino is connected to c #, I can not open the serial monitor on arduino .In this case i can not control the output . my head is very mixed, I need a clue
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
Here my c# code I am sending like this "123#433" and I am trying to read this data , You can see my arduino code below it's not working clearly servo motor turning freak.
                   int second = 0;
                            int offset = 300;
                            map = (float)0.85 * second;
                            int second2 = 0;
                            int offset2 = 300;
#include <Servo.h>
Servo servo1;
const byte charnumarasi = 32;
char gelenchar[charnumarasi];
int i ;
boolean newData = false;
int datanumarasi = 0;
     servo1.attach(2);
   for (i = 0; i < 180; i++) {
   servo1.write(i);
   delay(150);
 servo1.write(90);
   isaret();
   numarayigoster();
void isaret() {
   static byte index = 0;
   char isaret = '#';
   char alinanveri;
   if (Serial.available() > 0) {
       alinanveri = Serial.read();
       if (alinanveri != isaret) {
           gelenchar[index] = alinanveri;
           index++;
           if (index >= charnumarasi) {
               index = charnumarasi - 1;
       else {
           gelenchar[index] = '\0'; // stringi kapat
           index = 0;
           newData = true;
void numarayigoster() {
   if (newData == true) {
       datanumarasi = 0;
       datanumarasi = atoi(gelenchar); // yeni olan
       // new for this version
     servo1.write(map( gelenchar[datanumarasi], 0, 255, 0, 180));
       Serial.println(gelenchar);
       Serial.println(datanumarasi);    // yeni olan
       newData = false;
Hold on. You read 123 into datanumerasi, then you use it to access the 123rd character in gelenchar? Is your buffer even that long?
Your Arduino code in Reply #5 looks like it is a conversion of my Serial Input Basics into another language (which is fine) but if you are sending "123#433" you should not be using the # character as the end marker. That would work if you were sending "123#433#" as it would see it as two complete messages.
When you send "123#433" you should look for the real end-marker - the character that is sent after the 433, which is probably a carriage-return or line-feed. And when you have received the "123#433" you should use the parse example to split it into two numbers using the # character as the delimiter. My example code assumes a comma is used as a delimiter but you could change that. Or you could get your C# program to send a comma in place of the #
...R
Thank you Robin You really explained it very well , I just changed conversion float to integer. if anyone finding servo control with parsing data your code is working very good.As you said, I made the decisive statement in c # .Thank you again
// Example 5 - Receive with start- and end-markers combined with parsing
#include <Servo.h>
Servo servo1;
Servo servo2;
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
     // variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
   servo1.attach(2);
   servo2.attach(4);
   recvWithStartEndMarkers();
       strcpy(tempChars, receivedChars);
           // this temporary copy is necessary to protect the original data
           //   because strtok() used in parseData() replaces the commas with \0
       parseData();
       showParsedData();
       newData = false;
void recvWithStartEndMarkers() {
   static boolean recvInProgress = false;
   static byte ndx = 0;
   char startMarker = '<';
   char endMarker = '>';
   char rc;
   while (Serial.available() > 0 && newData == false) {
       rc = Serial.read();
       if (recvInProgress == true) {
           if (rc != endMarker) {
               receivedChars[ndx] = rc;
               ndx++;
               if (ndx >= numChars) {
                   ndx = numChars - 1;
           else {
               receivedChars[ndx] = '\0'; // terminate the string
               ndx = 0;
               newData = true;
       else if (rc == startMarker) {
           recvInProgress = true;
void parseData() {      // split the data into its parts
   char * strtokIndx; // this is used by strtok() as an index
   strtokIndx = strtok(tempChars,",");      // get the first part - the string
   strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
   strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
   integerFromPC = atoi(strtokIndx);     // convert this part to an integer
servo1.write(map(integerFromPC, 0, 255, 0, 180));
   floatFromPC = atoi(strtokIndx);     // convert this part to a float
servo2.write(map(floatFromPC, 0, 255, 0, 180));
void showParsedData() {
