I'm working on an Arduino program that will display the result of any two distinct numbers from 1 to 5 entered via the keypad on a seven-segment display. but I can't seem to figure out how to connect the keypad with a single seven-segment led to display my result.
This is my circuit:
This is my code:
// C++ code
#include <Keypad.h>
// number of the pin
int a= 7; //7
int b= 8; //6
int c= 9; //4
int d= 10; //2
int e= 11; //1
int f= 12; //9
int g= 13; //10
void number0(){
digitalWrite(a, HIGH); //0
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, LOW);
void number1(){
digitalWrite(a, LOW); //1
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
void number2(){
digitalWrite(a, HIGH); //2
digitalWrite(c, LOW);
digitalWrite(g, HIGH);
void number3(){
digitalWrite(a, HIGH); //3
void number4(){
digitalWrite(a, LOW); //4
void number5(){
digitalWrite(a, HIGH); //5
digitalWrite(b, LOW);
void number6(){
digitalWrite(a, HIGH); //6
void number7(){
digitalWrite(a, HIGH); //7
void number8(){
digitalWrite(a, HIGH); //8
void number9(){
digitalWrite(a, HIGH); //9
void blank(){
digitalWrite(a, LOW); //blank
const byte Rows = 4; //four rows
const byte Cols = 4; //three columns
char keys[Rows][Cols] = {
{'1','2','3','+'},
{'4','5','6','-'},
{'7','8','9','*'},
{'C','0','#','/'}
byte rowPins[Rows] = {6,5,4,3}; //connect to the row pinouts of the keypad
byte colPins[Cols] = {2,1,0,A0}; //connect to the column pinouts of the keypad
Keypad myKeypad = Keypad(makeKeymap(keys),rowPins,colPins,Rows,Cols);
boolean presentValue = false;
boolean next = false;
boolean final = false;
String num1, num2;
int answer;
char op;
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
while (!Serial);
Serial.println("Enter two distinct numbers from (1 - 5)");
char key = myKeypad.getKey();
if (key != NO_KEY && (key=='1'||key=='2'||key=='3'||key=='4'||key=='5'||key=='6'||key=='7'||key=='8'||key=='9'||key=='0')){
if (presentValue != true){
num1 = num1 + key;
int numLength = num1.length();
num2 = num2 + key;
int numLength = num2.length();
final = true;
else if (final == true && key != NO_KEY && key == '='){
if (op == '+'){
answer = num1.toInt() + num2.toInt();
else if (op == '-'){
answer = num1.toInt() - num2.toInt();
else if (op == '*'){
answer = num1.toInt() * num2.toInt();
else if (op == '/'){
answer = num1.toInt() / num2.toInt();
else if (key != NO_KEY && key == 'C'){
final = false;
num1 = "";
num2 = "";
answer = 0;
op = ' ';
