Hello,
I am trying to make a calibrate button for the accelerometer.
This is the code to calibrate it:
mySensor.calibrateOffset(Ax, Ay, Az);
where Ax, Ay and Az are the calibrations of the sensor.
I made a simple code to calibrate it by reading the current x, y and z value and do it *1 or *-1 and put that into the Ax, Ay and Az.
if (xPos < 0) {
Ax = xPos * -1;
else if (xPos == 0) {}
else {
Ax = -xPos - CalibrateArray[0][1];
But every time I recalibrate it after moving it, it takes the first values before the calibration.
So if it starts reading X = 20, I calibrate it with -10 (push button to run that small code above) so X = 0, then I move it till X becomes 5, Calibrate again, it reads 5, so it does -5 on the first reading, meaning X will become 15 (20-5=15).
I had in mind to make a 2D array to save values of X, Y and Z twice and add or remove the old value with the new readings.
void Accelerometer::calibrate() {
ReadArray[0] = xPos;
ReadArray[1] = yPos;
ReadArray[2] = zPos;
CalibrateArray[0][0] = Ax;
CalibrateArray[1][0] = Ay;
CalibrateArray[2][0] = Az;
Serial.println("Array 0:");
Serial.print((int)CalibrateArray[0][0]);
Serial.print('\t');
Serial.print((int)CalibrateArray[1][0]);
Serial.print('\t');
Serial.println((int)CalibrateArray[2][0]);
Serial.println("Array 1:");
Serial.print((int)CalibrateArray[0][1]);
Serial.print('\t');
Serial.print((int)CalibrateArray[1][1]);
Serial.print('\t');
Serial.println((int)CalibrateArray[2][1]);
if (xPos < 0) {
Ax = xPos * -1 + CalibrateArray[0][1];
else if (xPos == 0) { }
else {
if (yPos < 0) {
Ay = yPos * -1 + CalibrateArray[1][1];
else if (yPos == 0) { }
else {
Ay = -yPos - CalibrateArray[1][1];
if (zPos < 0) {
Az = zPos * -1 + CalibrateArray[2][1];
else if (zPos == 0) { }
else {
Az = -zPos - CalibrateArray[2][1];
mySensor.calibrateOffset(Ax, Ay, Az); // Calibreer x, y, z
delay(100);
CalibrateArray[0][1] = CalibrateArray[0][0];
CalibrateArray[1][1] = CalibrateArray[1][0];
CalibrateArray[2][1] = CalibrateArray[2][0];
delay(100);
Serial.println("-----------");
Serial.println("Calibrated");
Serial.print('\t');
Serial.print('\t');
Serial.print('\t');
Serial.print('\t');
Serial.println("+++++++++++++++++++");
This is the code I made, but I can't seem to get it calibrate correctly.
