Calling enum issue
Hello,
I have tried to utilize the enum function to label the values that need to be handled via array like so:
int ParameterReadAddress[27] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0C, 0x0D, 0x0E, 0x0F, 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1C, 0x1D};
int ParameterReadValue[27];
enum ParameterReadName {
  OutputFrequency,
  CommandedFrequency,
  OutputVoltage,
  DCBusVoltage,
  DriveStatus,
  Fault1Code,
  Fault2Code,
  Fault3Code,
  ProcessDisplay,
  ControlSource,
  ContrlInStatus,
  DigInStatus,
  ControlSWVer,
  DriveType,
  ElapsedRunTime,
  TestpointData,
  AnalogIn0to10V,
  OutputPower,
  OutputPowerFctr,
  DriveTemp,
  CounterStatus,
  TimerStatus,
  StpLogicStatus,
  TorqueCurrent
Later on, I try to call this:
void CheckFlag() {
  StartFlag = 1;
if (ParameterReadValue[ParameterReadName OutputFrequency] > 30) {
    StartFlag = 0;
This is not working and throwing the error:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
VFD_Control:346:44: error: expected primary-expression before 'OutputFrequency'
VFD_Control:346:44: error: expected ']' before 'OutputFrequency'
VFD_Control:346:44: error: expected ')' before 'OutputFrequency'
VFD_Control:346:59: error: expected primary-expression before ']' token
exit status 1
I have tried following examples of the enum function, but this it clearly not working. Does anyone have any advice on how to properly use the enum, or if I'm missing something?
Thank you in advance,
JPM
What makes you think you can string multiple identifiers one after the other? The compiler is trying to tell you... "hey, I need to see a ] because you're done there".
It should probably just be,
if (ParameterReadValue[OutputFrequency] > 30) {
Maybe you meant 'ParameterReadName::OutputFrequency'?
From snippets of code, who can know for sure?
