Already got help from forum regarding enum. Don't find that thread therefor opening a new thread.
I don't get it, what the error message tell.
Anybody that see my mistake and have a suggestion?
The code:
#include<arduino.h>
//I2C for LCD
#include <AccelStepper.h>
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
hd44780_I2Cexp mylcd; // declare lcd object: auto locate & config exapander chip
AccelStepper myStepper (7, 8);
// LCD geometry
#define LCD_COLS 16
#define LCD_ROWS 2
enum mode {Sides, Angle };
int faces = 4;
unsigned long nrOfStepsPerRev = 90L * 200 * 4; // microstep 4
enum cmd {increase, decrease, Go, Chg, nobutton};
unsigned long anglePos;
//1Hz 90% dutycycle
pinMode(9, OUTPUT); // Set digital pin 9 (D9) to an output
TCCR1A = _BV(COM1A1) | _BV(COM1A0) | _BV(WGM11); // Enable the PWM output OC1A on digital pins 9 and invert output
TCCR1B = _BV(WGM13) | _BV(WGM12) | _BV(CS12); // Set fast PWM and prescaler of 256 on timer 1
ICR1 = 62499; // Set the PWM frequency to 1Hz: 16MHz/(256 * 1Hz) - 1 = 62499
OCR1A = 6249; // Set the duty-cycle to 10%: 62499 / 10 = 6249
pinMode(10, OUTPUT); // 1 Hz pulse output on digital pin 9 (D9)
pinMode(13, OUTPUT); digitalWrite(13, LOW);// Make board LED go off
delay(10);//allow pwm timers to start
// myStepper.begin();
myStepper.setMaxSpeed(500);
myStepper.setAcceleration(10);
#define digitalIncreaseButton 2
pinMode (digitalIncreaseButton, OUTPUT);
#define digitalDecreaseButton 3
pinMode (digitalDecreaseButton, OUTPUT);
#define digitalChgButton 4
pinMode(digitalChgButton, OUTPUT);
#define digitalGoButton 5
#define guard1 6
#define guard2 7
#define cuttingSpeed 100 // when cutting during rotation
#define movingSpeed 2000 //when moving without cutting
int status;
status = mylcd.begin(LCD_COLS, LCD_ROWS);
if (status) // non zero status means it was unsuccesful
status = -status; // convert negative status value to positive number
// begin() failed so blink error code using the onboard LED if possible
hd44780::fatalError(status); // does not return
mylcd.clear();
// Print start message to the LCD
mylcd.print("221101a Rotating");
delay(5000);
mylcd.print("Running");
enum cmd readButtons(void)
if ((digitalIncreaseButton) == 0) return (increase);
if ((digitalDecreaseButton) == 0) return (decrease);
if ((digitalGoButton) == 0) return (Go);
if ((digitalChgButton) == 0) return (Go);
return (nobutton);
boolean guardCheck(void)
if (!digitalRead(guard1) && !digitalRead(guard2))
return (true);//Unlocked, clear to go
return false;//Locked, don't go
unsigned long lastMillis;
enum cmd lcmd;
lcmd = readButtons();// Read button inputs if any + - Go Chg mode
if ( millis() - lastMillis > 200 )
lastMillis = millis();
if ( mode == Sides ) //number of surfaces
switch (lcmd)
case increase:
faces++;
case decrease:
faces--;
if (faces < 2)
faces = 1; //1 rotate one turn
myStepper.setMaxSpeed(cuttingSpeed);
myStepper.setMaxSpeed(movingSpeed);
case Chg:
mode == Angle; //switch to angle mode
myStepper.setMaxSpeed(movingSpeed);// used i angle mode
case Go:
while (!guardCheck());;//DON*T GO IF LOCKS ARE ON
myStepper.runToNewPosition(anglePos);//Blocking until done
anglePos += nrOfStepsPerRev * 360 / faces;
default:
}//end of switch
}//end of "if (mode == Sides)"
else if ( mode == Angle ) // Angle per step
switch (lcmd)
case increase:
anglePos += nrOfStepsPerRev * 5 / 360; //Increase by 5 degrees
case decrease:
anglePos -= nrOfStepsPerRev * 5 / 360; //Increase by 5 degrees
// if (faces < 1) faces = 1; //1 rotate one turn
case Chg:
mode == Sides; //switch to sides mode
// goFlag = false;//
case Go:
default:
if (guardCheck())
myStepper.run();
}// End of loop
moveTo KEYWORD2
move KEYWORD2
run KEYWORD2
runSpeed KEYWORD2
setMaxSpeed KEYWORD2
setAcceleration KEYWORD2
setSpeed KEYWORD2
speed KEYWORD2
distanceToGo KEYWORD2
targetPosition KEYWORD2
currentPosition KEYWORD2
setCurrentPosition KEYWORD2
runToPosition KEYWORD2
runSpeedToPosition KEYWORD2
runToNewPosition KEYWORD2
stop KEYWORD2
disableOutputs KEYWORD2
enableOutputs KEYWORD2
setMinPulseWidth KEYWORD2
setEnablePin KEYWORD2
setPinsInverted KEYWORD2
maxSpeed KEYWORD2
enum flag {const1, const2, ..., constN};
By default, const1 is 0, const2 is 1 and so on. You can change default values of enum elements during declaration (if necessary).
// Changing default values of enum constants
enum suit {
club = 0,
diamonds = 10,
hearts = 20,
spades = 3,
Error message:
C:\Users\Stefan\Documents\Arduino\Rotation_20221101a\Rotation_20221101a.ino: In function 'void loop()':
Rotation_20221101a:100:15: error: expected primary-expression before '==' token
Rotation_20221101a:123:18: error: expected unqualified-id before '==' token
Rotation_20221101a:138:20: error: expected primary-expression before '==' token
Rotation_20221101a:155:18: error: expected unqualified-id before '==' token
exit status 1
