Can anyone help me solve the errors?
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#define BLACK   0x0000
#define RED     0xF800
#define WHITE   0xFFFF
#define GREEN   0x07E0
#define DARKGREEN 0x03E0
#define DARKGREY 0x7BEF
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
MCUFRIEND_kbv tft;
float roomTemp;
float objectTemp, stemp;
int readcount = 0;
int threshold = 0;
// ULTRASONIC SENSOR PREPARATION
#define echoPin 11
#define trigPin 12
int maximumRange = 25;
int minimumRange = 15;
long distance;
long duration;
int dtime;
    uint16_t ID = tft.readID();
    tft.begin(ID);
    pinMode(trigPin, OUTPUT);
    pinMode(echoPin, INPUT);
    tft.begin();
    tft.setTextColor(WHITE);
  digitalWrite (trigPin, LOW);
  delayMicroseconds (2);
  digitalWrite (trigPin, HIGH);
  delayMicroseconds (10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration*0.034/2;
  objectTemp = threshold + mlx.readObjectTempC();
  roomTemp = mlx.readAmbientTempC();
  Serial.println("Object:" + String(objectTemp) + ", Ambient:" + String(roomTemp));
  Serial.println(distance);
  tft.setTextSize(1);
  tft.setCursor(0, 25);
  tft.print("Dis:" + String(distance) + "cm");
  tft.setCursor(65, 25);
  tft.print("Room:" + String(roomTemp).substring(0, 4) + "C");
  tft.setTextSize(2);
  tft.setCursor(0, 0);
  if (distance > maximumRange)
      tft.print("GET CLOSER");
    if (distance < minimumRange)
        tft.print("TOO CLOSE!");
        if (readcount == 5)
            distemp();
              tft.print("HOLD ON");
              stemp = stemp + objectTemp;
              readcount++;
              dtime = 200;
    else{
      dtime = 100;
      readcount = 0;
      stemp = 0;
        delay(dtime);
        tft.println("count :" + String(readcount));
void distemp()
  objectTemp = stemp / 5;
  tft.setTextSize(1);
  tft.print("YOUR TEMP:");
  tft.setTextSize(2);
  tft.setCursor(60, 5);
  tft.print(String(objectTemp).substring(0, 4) + "C");
  readcount = 0;
  stemp = 0;
  if (objectTemp >= 37.5)
      play_alert();
        play_ok();
      dtime = 5000;
    void play_ok()
        tone (3, 600, 1000);
        delay (200);
        tone (3, 750, 500);
        delay (100);
        tone (3, 1000, 500);
        delay (200);
        noTone(3);
    void play_alert()
        tone (3, 2000, 1000);
        delay (1000);
        tone (3, 3000, 100);
        delay (1000);
        tone (3, 4000, 1000);
        delay (1000);
        noTone(3);
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
02-22-22:91:5: error: expected unqualified-id before 'else'
** else{**
02-22-22:97:14: error: expected constructor, destructor, or type conversion before '(' token
** delay(dtime);**
02-22-22:98:9: error: 'tft' does not name a type
** tft.println("count :" + String(readcount));**
exit status 1
option enabled in File -> Preferences.
Make sure you indented the code in the IDE, that's done by pressing ctrlT on a PC or cmdT on a Mac)
You'll see that you have an wrongly placed closing } in the loop (line 90), which makes some of the code fall out any function.
if you fix this you'll still have other challenges, make sur all your else are attached to an if and that () and {} are balanced
NOW THIS IS THE ERROR
#include <Wire.h>
#define RED     0xF800
MCUFRIEND_kbv tft;
float roomTemp;
int readcount = 0;
int threshold = 0;
#define echoPin 11
#define trigPin 12
long distance;
long duration;
int dtime;
  tft.begin(ID);
  tft.begin();
  distance = duration * 0.034 / 2;
  tft.setTextSize(1);
  tft.setTextSize(2);
  if (readcount == 5)
    distemp();
    readcount++;
    dtime = 200;
  else {
    dtime = 100;
    readcount = 0;
    stemp = 0;
  delay(dtime);
void distemp()
  tft.setTextSize(1);
  tft.setTextSize(2);
  readcount = 0;
  stemp = 0;
    play_alert();
    play_ok();
  dtime = 5000;
void play_ok()
  delay (200);
  tone (3, 750, 500);
  delay (100);
  delay (200);
  noTone(3);
void play_alert()
  delay (1000);
  delay (1000);
  delay (1000);
  noTone(3);
C:\Users\user\Documents\Arduino\02-22-22\02-22-22.ino: In function 'void loop()':
02-22-22:90:3: error: 'else' without a previous 'if'
** else {**
exit status 1
  if (readcount == 5)
    distemp();
    readcount++;
    dtime = 200;
  else {
    dtime = 100;
    readcount = 0;
    stemp = 0;
You can only have one 'else' per 'if'. You can have multiple 'elseif's but only one 'else'. Not too sure of your logic, maybe you needed nested if/else statements to achieve what you were going for?
You can't have an 'else {} else {}'. You can only put an 'else' on an 'if': 'if () {} else {}'
yes, as I said above
how about this one?
Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 26944 bytes (10%) of program storage space. Maximum is 253952 bytes.
Global variables use 622 bytes (7%) of dynamic memory, leaving 7570 bytes for local variables. Maximum is 8192 bytes.
avrdude: verification error, first mismatch at byte 0x036c
** 0x30 != 0x70**
avrdude: verification error; content mismatch
initially you were compiling for a UNO and now for a MEGA....
which board do you have?
mega 2560 sir
did you check the common issues?
yes sir. i already checked
what did the loopback test show?
Did you
  1. Check that your USB cable is working. Test it with a different device, or try using a different USB cable. Make sure it is a data cable, a charge-only cable will not work.
Or a different USB gazinta, or with or without a hub &c.
Also not mentioned or I didn't see it is to reboot your machine.
It's probably the only reason I ever have to… I can go weeks with no trouble, other times right away but sometimes my USB ports become, one by one, locked out unavailable.
I have found no other way to force the USB subsystem to reset itself.
a7
