Can anyone help me to program a line follower based pick up and place robot
I am from bangladesh.i have a project of line follower based pick up and place robot.but I am new in robotics.so I can not do the program of this line follower based pick up and place robot.can anyone help me?????
Yes. Many experienced and knowledgeable forum members will be pleased to help you. But most of them will not do the coding for you. Forum members want to help you to learn to code. Coding is an important skill to learn if you want to build a robot.
Do not begin by attempting to write the whole code for the robot. Begin with the most simple actions like moving forward and stopping, not even following a line. Write code and test it until it is working. Then add another simple function, test again and then add a third simple function. Progressing step by step will help you learn to write code without the code becoming too complex too quickly.
I've deleted your other cross-post @adnanc28921.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
