Line following robot package picker
Hi everyone,
I wrote some code for a line following robot that is used to pick up a box using pincers. See photo attached. It is meant to do the following functions:
  1. Follow a line by using your line sensors.
  2. Detect a box placed along the line using your ultrasonic sensor.
  3. Pick up the box using the forks on your rover.
  4. Continue to follow the line until a wall/barrier is detected at 15 cm.
  5. Lower the box onto the floor.
  6. Move backwards until the box is at 15 cm.
My code seems to compile and run but when it gets to the second operation it automatically reverts back to 0 and I can't seem to understand why.
Any help would be appreciated.
#include <ArduinoMotorCarrier.h>
int operation = 0; // Initialize operation variable
int R_S = A7;
int L_S = A2;
int state1;
int state2;
const int trig = A6; // TRIG pin
const int echo = A3; // ECHO pin
const int led = 8; // LED Pins
const float c = 343; // Speed of sound [m/s]
float t; // Time Variable
float distance; // Distance Variable
  controller.begin();
  pinMode(R_S, INPUT);
  pinMode(L_S, INPUT);
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
  pinMode(led, OUTPUT);
  servo3.setAngle(30);
  operation = 0;
  state1 = analogRead(R_S);
  state2 = analogRead(L_S);
  Serial.write("left ");
  Serial.println(state2);
  Serial.write("right ");
  Serial.println(state1);
  Serial.write("distance ");
  Serial.println(distance);
  Serial.println(operation);
  distancemeasure();
  //digitalWrite(trig, HIGH); // Start ultrasound
  ////delayMicroseconds(10); // 10 microsecond delay
  //digitalWrite(trig, LOW); // End ultrasound
  //t = pulseIn(echo, HIGH); // Measure time taken [microseconds]
  //t = t*(0.000001); // [microseconds] -> [seconds]
  //distance = (t/2)*c; // distance [meters]
  //distance = distance*100; // [meters] -> [centimeters]
  if (distance > 5) //block not seen
    operation = 0;
    operation = 1;
  if (operation == 0)
    servo3.setAngle(140);
    servo1.setAngle(40);
    linefollow();
  if (operation == 1)
    delay(100);
    pick();
    delay(3000);
    operation = operation + 1;
  if (operation == 2)
    distancemeasure();
    if (distance > 15)
      linefollow2();
      //  delay(1000);
    else if (distance < 15)
      stoprover();
      delay(3000);
      delay(3000);
  if (operation == 3)
    servo1.setAngle(0);
    reverse();
    delay(3000);
  if (operation == 4)
    stoprover();
    delay(10000);
//FUNCTIONS
void linefollow()
  if ((state1 < 70) && (state2 < 70)) //forward
    M1.setDuty(18);
    M2.setDuty(18);
    Serial.println(19);
  else if ((state1 > 70) && (analogRead(L_S) < 70)) //right high therefore right turn
    //RightTurn(30,15);
    M1.setDuty(8);
    M2.setDuty(20);
  else if ((analogRead(R_S) < 70) && (analogRead(L_S) > 70)) //left high therefore left turn
    //LeftTurn(15,30);
    M1.setDuty(20);
    M2.setDuty(8);
  else if ((analogRead(R_S) > 70) && (analogRead(L_S) > 70)) //stop
    M1.setDuty(0);
    M2.setDuty(0);
void go()
  M1.setDuty(25);
  M2.setDuty(25);
void reverse()
  M1.setDuty(-25);
  M2.setDuty(-25);
void pick()
  M1.setDuty(0);
  M2.setDuty(0);
  servo3.setAngle(0);
  servo1.setAngle(140);
  delay(5000);
void stoprover()
  M1.setDuty(0);
  M2.setDuty(0);
void linefollow2()
  servo1.setAngle(120);
    M1.setDuty(18);
    M2.setDuty(20);
    //RightTurn(30,15);
    M1.setDuty(8);
    M2.setDuty(22);
    //LeftTurn(15,30);
    M1.setDuty(20);
    M2.setDuty(8);
    M1.setDuty(0);
    M2.setDuty(0);
void distancemeasure()
  //  // put your main code here, to run repeatedly:
  //delayMicroseconds(10000); // 10 microsecond delay
  t = t * (0.000001); // [microseconds] -> [seconds]
  distance = (t / 2) * c; // distance [meters]
  distance = distance * 100; // [meters] -> [centimeters]
  Serial.print("distance: "); // Print "Distance"
  Serial.print(distance); // Print Measured Distance
  Serial.println(" cm"); // Print Distance Units
  delay(50);
Is this a follow-on question from LEDS with distance sensor and for loop
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi, yes it is similar to the LED one but its not the exact same and that's why I kept it as a separate post. I have fixed the code though to be formatted properly
Please use the autoformat function in the IDE to make real formatting.
I'm sorry, I dont see how the formatting is supposed to be different from how it is now? If it's causing an issue I really do apologize but I was hoping to get some help regarding the code?
Auto Formatting the code makes the code blocks easier to see which can be helpful when multiple if/else is involved
Your code Auto Formatted
int R_S = A7;
int L_S = A2;
int state1;
int state2;
  controller.begin();
  operation = 0;
  distancemeasure();
    operation = 0;
    operation = 1;
  if (operation == 0)
    linefollow();
  if (operation == 1)
    delay(100);
    pick();
    delay(3000);
  if (operation == 2)
    distancemeasure();
    if (distance > 15)
      linefollow2();
      //  delay(1000);
      stoprover();
      delay(3000);
      delay(3000);
  if (operation == 3)
    servo1.setAngle(0);
    reverse();
    delay(3000);
  if (operation == 4)
    stoprover();
    delay(10000);
//FUNCTIONS
void linefollow()
    M1.setDuty(18);
    M2.setDuty(18);
    Serial.println(19);
    //RightTurn(30,15);
    M1.setDuty(8);
    M2.setDuty(20);
    //LeftTurn(15,30);
    M1.setDuty(20);
    M2.setDuty(8);
    M1.setDuty(0);
    M2.setDuty(0);
void go()
  M1.setDuty(25);
  M2.setDuty(25);
void reverse()
  M1.setDuty(-25);
  M2.setDuty(-25);
void pick()
  M1.setDuty(0);
  M2.setDuty(0);
  servo3.setAngle(0);
  delay(5000);
void stoprover()
  M1.setDuty(0);
  M2.setDuty(0);
void linefollow2()
    M1.setDuty(18);
    M2.setDuty(20);
    //RightTurn(30,15);
    M1.setDuty(8);
    M2.setDuty(22);
    //LeftTurn(15,30);
    M1.setDuty(20);
    M2.setDuty(8);
    M1.setDuty(0);
    M2.setDuty(0);
  delay(50);
I copied and pasted the formatted code above.
There are only 2 ways in your code that operation can be set back to 0. First is in setup() so put a Serial.println() statement in setup after Serial.begin(). Second is in loop() when distance > 5. Put a Serial.println() in that conditional.
If it is a reset then it is usually a power issue. How are your servos powered? Do they have a separate source from the Arduino? They need to be powered separately or they cause a voltage drop which causes the Arduino to get reset.
