Hello!
I have a custom PCB, which was planned to be used with ATmega2560-16AU, with the picture below showing the schematic of its circuit.
Now problem occurred when I've tried to burn the bootloader via ArduinoISP sketch, using Arduino Uno board and "Arduino as ISP" programmer. I've tried to find a similar problems on the forum prior to opening the topic, but without any result. Below I'm adding the output log of the bootloading process:
"C:\Users\uidk5053\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\uidk5053\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega2560 -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/* -
Copyright (c) 2007-2014 Joerg Wunsch* -
System wide configuration file is "C:\Users\********\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"* -
Using Port : COM6* -
Using Programmer : stk500v1* -
Overriding Baud Rate : 19200* -
AVR Part : ATmega2560* -
Chip Erase delay : 9000 us* -
PAGEL : PD7* -
BS2 : PA0* -
RESET disposition : dedicated* -
RETRY pulse : SCK* -
serial program mode : yes* -
parallel program mode : yes* -
Timeout : 200* -
StabDelay : 100* -
CmdexeDelay : 25* -
SyncLoops : 32* -
ByteDelay : 0* -
PollIndex : 3* -
PollValue : 0x53* -
Memory Detail :* -
Block Poll Page Polled* -
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack* -
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00* -
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00* -
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00* -
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00* -
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00* -
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00* -
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00* -
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00* -
Programmer Type : STK500* -
Description : Atmel STK500 Version 1.x firmware* -
Hardware Version: 2* -
Firmware Version: 1.18* -
Topcard : Unknown* -
Vtarget : 0.0 V* -
Varef : 0.0 V* -
Oscillator : Off* -
SCK period : 0.1 us*
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xD8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD8:
avrdude: load data hfuse data from input file 0xD8:
avrdude: input file 0xD8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
"C:\Users*\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users*\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega2560 -cstk500v1 -PCOM6 -b19200 "-Uflash:w:C:\Users******\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:i" -Ulock:w:0x0F:m
PAGEL : PD7* -
BS2 : PA0* -
Timeout : 200* -
StabDelay : 100* -
CmdexeDelay : 25* -
SyncLoops : 32* -
ByteDelay : 0* -
PollIndex : 3* -
PollValue : 0x53* -
Memory Detail :* -
Vtarget : 0.0 V* -
Varef : 0.0 V* -
Oscillator : Off* -
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override* -
this check.*
Failed to burn bootloader: uploading error: exit status 1
Now after this attempt, every attempt to burn the bootloader gives back "Device signature = 0x000000", which I don't get why, since wiring is obviously okay because at the beginning device signature was properly read.
