Sorry if this topic has been covered too many times, but I am confused on which modules to use for my project.
I have been building an Arduino dashboard to display engine data (RPM, temperature, etc.) from a Motec ECU using it's CAN-BUS wires (no OBDII port). I have seen many other projects doing something similar, but have approached it in many different ways, such as using Teensy's and a CAN-BUS shield from Sparkfun.
I am currently using a Mega2560. Due to size limitations and lack of port, the shield cannot be used. I have seen others using modules like the MCP2551, MCP2515, and even SN65HVD230. Some have used one, while others have shown using them in conjunction. Since I am only receiving data from the ECU to display on a screen on the Arduino and not sending commands, which module(s) should I use?
I have been looking at these:
MCP2515: https://www.newegg.com/p/0MJ-015K-005N9?Item=9SIAGAH9B61772
MCP2551: MCP2551 high-speed CAN protocol controller bus interface module - Newegg.com
SN65HVD230: SN65HVD230 CAN bus transceiver communication module for arduino - Newegg.com
Thank you.
