I am trying to Send 4 analog signals to the can bus with bytes 1 and 2 analog 0, bytes 3 and 4 analog1, bytes 5 and 6 analog 2, and bytes 7 and 8 analog 3. I want it to output in a 0-500 (0-5.00volts) format. The code is working for bytes 1 and 2, but all the other bytes are mirroring analog 0. no matter what i try, all channels are mirroring bytes 1 and 2. any advice?
#include <mcp_canbus.h>
#include <SPI.h>
const int SPI_CS_PIN = 17; // CANBed V1
// const int SPI_CS_PIN = 3; // CANBed M0
// const int SPI_CS_PIN = 9; // CAN Bus Shield
int Analog0_Raw;
int Analog0_Volt;
int Analog0_VoltHigh;
int Analog0_VoltLow;
int Analog1_Raw;
int Analog1_Volt;
int Analog1_VoltHigh;
int Analog1_VoltLow;
int Analog2_Raw;
int Analog2_Volt;
int Analog2_VoltHigh;
int Analog2_VoltLow;
int Analog3_Raw;
int Analog3_Volt;
int Analog3_VoltHigh;
int Analog3_VoltLow;
MCP_CAN CAN(SPI_CS_PIN);
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
CAN.begin(CAN_1000KBPS);
unsigned char stmp[8] = {Analog0_VoltHigh, Analog0_VoltLow, Analog1_VoltHigh, Analog1_VoltLow, Analog2_VoltHigh, Analog2_VoltLow, Analog3_VoltHigh, Analog3_VoltLow,};
Analog0_Raw = analogRead(A0);
Analog0_Volt = Analog0_Raw/2.046;
Analog0_VoltHigh=(Analog0_Volt/256);
Analog0_VoltLow=Analog0_Volt-(Analog0_VoltHigh*256);
Analog1_Raw = analogRead(A1);
Analog1_Volt = Analog1_Raw/2.046;
Analog1_VoltHigh=(Analog1_Volt/256);
Analog1_VoltLow=Analog1_Volt-(Analog1_VoltHigh*256);
Analog2_Raw = analogRead(A2);
Analog2_Volt = Analog2_Raw/2.046;
Analog2_VoltHigh=(Analog2_Volt/256);
Analog2_VoltLow=Analog2_Volt-(Analog2_VoltHigh*256);
Analog3_Raw = analogRead(A3);
Analog3_Volt = Analog3_Raw/2.046;
Analog3_VoltHigh=(Analog3_Volt/256);
Analog3_VoltLow=Analog3_Volt-(Analog3_VoltHigh*256);
CAN.sendMsgBuf(0x91, CAN_STDID, 8, stmp);
delay(10); // send data per 10ms
i need it to come back as whole numbers, that part of the code works fine for analog 0 to bytes 1 and 2. I have a pot on it and it reads 0 at one end and 500 at another end. exactly how I want it to read. the issue is, when I look at bytes 3 and 4, they also follow the pot that is on analog0 and I have it disconnected.
im a beginner on this so any help is appreciated. thanks
when i put Analog1_Raw, or (2 or 3) in the serial monitor it follows what Analog0_Raw is doing. this is before any conversions or anything. should just be whatever the pin is reading. if i put a voltmeter on the pin it reads 0v.
Here is what the serial is doing when i run this code. Note that analog1,2 and 3 are all reading 0 voltage on a meter and are not hooked up to anything.
14:14:40.732 -> Analog 1:959
14:14:40.732 -> Analog 2:904
14:14:40.732 -> Analog 3:884
14:14:40.732 -> Analog 0:1022
14:14:40.732 -> Analog 1:970
14:14:40.732 -> Analog 2:920
14:14:40.732 -> Analog 3:888
14:14:40.732 -> Analog 0:1023
14:14:40.732 -> Analog 1:997
14:14:40.732 -> Analog 2:965
14:14:40.732 -> Analog 3:922
14:14:40.780 -> Analog 0:1023
#include <SPI.h>
int Analog0_Raw;
int Analog0_Volt;
int Analog1_Raw;
int Analog1_Volt;
int Analog2_Raw;
int Analog2_Volt;
int Analog3_Raw;
int Analog3_Volt;
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
CAN.sendMsgBuf(0x391, CAN_STDID, 8, stmp);
Serial.print("Analog 0:");
Serial.println (Analog0_Raw);
Serial.print("Analog 1:");
Serial.println (Analog1_Raw);
Serial.print("Analog 2:");
Serial.println (Analog2_Raw);
Serial.print("Analog 3:");
Serial.println (Analog3_Raw);
that worked. lol i knew it was something stupid i was doing, i grounded the 3 other inputs and they all read 0, if i move one to the pot it read the output voltage of the pot. Thank you for your help!
