I am making a temperature monitoring device Thermocouple is the main sensor and I am using thermistor for room temperature sensing. I want to print the value of the thermistor on lcd using interrupts and i want the value to stay about 5 secs. the code is working but i am unable to make a delay of about 5sec while staying on the interrupt
Your code?
HowToPostCode
#include "max6675.h"
#include<LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 9, 8, 7, 6);
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 3;
volatile boolean ledOn = false;
const int sensor=A1;
int tempc; //variable to store temperature in degree Celsius
int tempf; //variable to store temperature in Fahreinheit
float vout; //temporary variable to hold sensor reading
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
pinMode(sensor,INPUT); // Configuring pin A1 as input
pinMode(2,INPUT);
pinMode(13,OUTPUT);
attachInterrupt(0,buttonPressed,RISING);
lcd.begin(16,2);
// wait for MAX chip to stabilize
void buttonPressed()
if(ledOn)
ledOn = false;
digitalWrite(13,LOW);
}else
ledOn = true;
digitalWrite(13,HIGH);
vout=analogRead(sensor);
vout=(vout*500)/1023;
lcd.setCursor(0,0);
lcd.print("ROOM TEMPERATURE");
lcd.setCursor(0,1);
lcd.print("Degree in C = ");
lcd.print(tempc);
//I WANT A 5 SECOND DELAY HERE
// basic readout test, just print the current temp
{Serial.print("C = ");
Serial.println(thermocouple.readCelsius(),1);
Serial.print("F = ");
Serial.println(thermocouple.readFahrenheit(),1);
lcd.setCursor(0,0);
lcd.print("TEMPERATURE IS ");
lcd.setCursor(0,1);
lcd.print("C = ");
lcd.print(thermocouple.readCelsius(),1);
lcd.print("F = ");
lcd.print(thermocouple.readFahrenheit(),1);
delay(1000);} //Delay of 1 second for ease of viewing in serial monitor
You don’t really want a 5-second delay // HERE
You really want to setup a millis() timer and perform your function every 5 seconds. There’s a BIG difference.
Read up on “Using millis() as a timer / delay”
Why use interrupts?
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
It is hard to understand why there would be any requirement for interrupts in your project. Nothing seems to happen very quickly or only for a very brief time.
...R
