Can I power this Ultrasonic Piezoelectric Transducer without the commercial driver module kit and just with an Arduino and other components?
https://www.ctdco.com.tw/product_d.php?lang=en&tb=1&id=200*
Yes.
Thanks,
How? I'm a beginner in electronics, and I've been trying to figure out what components to use. What I've came up with is an N-Channel Mosfet as a switch, a 12V battery, the arduino as a controller, a voltage booster, diodes inductors heatsinks resistors etcetc so far... I'm really very unsure so that's why I reached out on here, thanks lol
I’m not but I have never designed a high power piezo driver, so I won’t try to advise you on how to do it. If you don’t know what you are doing you could easily damage the transducer and I would not want that to happen.
Buy the driver. That high power transducer is for professional equipment.
You clearly don't have the skills to design or build a driver, and it is unlikely that anyone on a hobby forum like this will be interested to help you do so.
The key specification is the maximum impedance of 35 Ohms at the resonant frequency. That tells you your AC driving signal must be able to supply power to a nearly zero value resistor. That is a lot of power and is AC, not DC from a mosfet. Get the factory driver and appropriate power supply.
