Can I switch these servos? Different max torque servos
So I have a question that needs to be answered as soon as possible.
I am building a hexapod that will weight around 3,5Kg-4 Kg (max).
This hexapod is based in a kit.
To build this robot you can either buy the frame only kit with no servos, or a kit that includes the hexapod frame and the 25 servos. The servos are the Hitec HS-645MG High Torque 2BB Metal Gear Servo, making this last kit unsurprisingly overpriced, since these motors are a bit expensive (making the price of motors only around 750€ (25 *31)
750€ calculated price for my country counting shipping as free.
FEATURES: Three metal gears.
Dual ball bearings.
Metal 1st Gear.
Four adjustable splined horns.
For use with .60 size helicopters, glow or electric cars and boats.
INCLUDES: One ultra torque servo with 11.5" connector wire.
One white small X-shaped servo horn.
One red Large X-shaped servo horn.
One white adjustable servo horn.
One white offset straight servo horn.
Four 2 x 14mm mounting screws
Four brass eyelets
Four black rubber vibration isolators.
SPECS: Speed: 0.24 sec/60° at 4.8V
0.20 sec/60° at 6.0V
Torque: 106.93 oz-in at 4.8V (7.7 kg-cm)
133.31 oz-in at 6.0V (9.6 kg-cm)
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
1st Question - Would I be able to use other servos, like the one below? If not, which ones can I use?
MG995 Digital Metal Gear Servo
Power Supply: Through External Adapter.
Stable and Shock Proof
Connector Wire Length 300mm
Operating Speed : 0.17sec / 60 degrees (4.8V no load)
Operating Speed : 0.13sec / 60 degrees (6.0V no load)
Stall Torque : 9 kg-cm (180.5 oz-in) at 4.8V
Stall Torque : 12 kg-cm (208.3 oz-in) at 6V
Operation Voltage : 4.8 - 7.2Volts
Gear Type: All Metal Gears
Original box: NO
Color: Black
Item size: 40 * 19 * 43mm
Servo weight: 55g
Net weight: 66g (with accessories)
Thanks in advance (btw if you know of any cool hexapod robots, say so! I'm all ears).
Volkun
Volkun:
What is your source for these servos? If it's ebay DON'T buy them. There are lots of fake servos on ebay.
I purchased some MG996R servos which turned out not to have ball bearings but they used bushings. These servos were junk.
I include a bill of material on the parts I used for my Halloween Hex. Make sure you follow the links to other places where I've documented the project. I need to fix a couple links since the new owners of Let's Make Robots (RobotShop) deleted all my posts from the site. The other links should still be good.
Well I wanted to make an a-pod from RobotShop :P. Starting with the hardware only kit and buying the motor servos here in my country (which is a pain, since prices are much higher then online of, so the source is not from ebay for sure.
And ofc buying the microcontroller and so on separately, since the hardware + servos kit is a ripoff.
DuaneDegn:
Do you think its possible to make a 3 DOF Mandible head with an Actobotics Horizontal Standard Gripper Kit A from robotshop??
Volkun:
I think that should be possible. There are lots of options to do something like this.
While I don't think ebay is a good place to buy servos, I think it's great for lots of other robot parts. If you use "robot claw" as your search terms, you'll see a bunch of options.
