Can i use Arduino to check i2c signal on Mobile phone board ? it Gives Scanning
Hello every one .
i have long time ago didnot use arduino ... now iam trying to use its at my work as mobile maintenance .
so i want to make application to scan i2c signal on mobile board i connected SDA , SCL to Prob Pionts on the iphone board like the 1st image .
and run the board from Power Supply and start scanning like the 2nd image ( note : i connected only 2 pins from arduino A4, A5 because i already feed and run the board from another source )
and used this code :
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// Version 6, November 27, 2015.
//    Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
  Wire.begin();
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
to scan the i2c i.cs. on the line .
its stuck on scanning like 3rd image
when i unplug the A5 pin its runes with error on device like 4th image
when i unplug the A4 pin its says no i2c device found like 5th image .
so now i got confused
i noticed another thing here in the code its ( Serial.begin(9600); ) and all another application i used form mobile maintenance using serial 115200
i tried multi speed code :
//    FILE: MultiSpeedI2CScanner.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.04
// PURPOSE: I2C scanner @different speeds
//    DATE: 2013-11-05
//     URL: http://forum.arduino.cc/index.php?topic=197360
// Released to the public domain
#include <Wire.h>
#include <Arduino.h>
// scans devices from 50 to 800KHz I2C speeds.
// lower than 50 is not possible
// DS3231 RTC works on 800 KHz. TWBR = 2; (?)
long speed[] = {
  50, 100, 200, 250, 400, 500, 800 };
const int speeds = sizeof(speed)/sizeof(speed[0]);
// DELAY BETWEEN TESTS
#define RESTORE_LATENCY  5    // for delay between tests of found devices.
bool delayFlag = false;
// MINIMIZE OUTPUT
bool printAll = true;
bool header = true;
// STATE MACHINE
enum states {
  STOP, ONCE, CONT, HELP };
states state = STOP;
uint32_t startScan;
uint32_t stopScan;
  Wire.begin();
  displayHelp();
  switch (getCommand())
  case 's':
    state = ONCE;
  case 'c':
    state = CONT;
  case 'd':
    delayFlag = !delayFlag;
    Serial.print(F("<delay="));
    Serial.println(delayFlag?F("5>"):F("0>"));
  case 'e':
    // eeprom test TODO
  case 'h':
    header = !header;
    Serial.print(F("<header="));
    Serial.println(header?F("yes>"):F("no>"));
  case '?':
    state = HELP;
  case 'p':
    printAll = !printAll;
    Serial.print(F("<print="));
    Serial.println(printAll?F("all>"):F("found>"));
  case 'q':
    state = HELP;
  default:
  switch(state)
  case ONCE:
    I2Cscan();
    state = HELP;
  case CONT:
    I2Cscan();
  case HELP:
    displayHelp();
    state = STOP;
  case STOP:
  default: // ignore all non commands
char getCommand()
  char c = '\0';
  if (Serial.available())
    c = Serial.read();
  return c;
void displayHelp()
  Serial.println(F("\nArduino I2C Scanner - 0.1.03\n"));
  Serial.println(F("\ts = single scan"));
  Serial.println(F("\tc = continuous scan - 1 second delay"));
  Serial.println(F("\tq = quit continuous scan"));
  Serial.println(F("\td = toggle latency delay between successful tests."));
  Serial.println(F("\tp = toggle printAll - printFound."));
  Serial.println(F("\th = toggle header - noHeader."));
  Serial.println(F("\t? = help - this page"));
void I2Cscan()
  startScan = millis();
  uint8_t count = 0;
  if (header)
    Serial.print(F("TIME\tDEC\tHEX\t"));
    for (uint8_t s = 0; s < speeds; s++)
      Serial.print(F("\t"));
      Serial.print(speed[s]);
    Serial.println(F("\t[KHz]"));
    for (uint8_t s = 0; s < speeds + 5; s++)
      Serial.print(F("--------"));
  // TEST
  // 0.1.04: tests only address range 8..120
  // Address	R/W Bit	Description
  // 0000 000   0	General call address
  // 0000 000   1	START byte
  // 0000 001   X	CBUS address
  // 0000 010   X	reserved - different bus format
  // 0000 011   X	reserved - future purposes
  // 0000 1XX   X	High Speed master code
  // 1111 1XX   X	reserved - future purposes
  // 1111 0XX   X	10-bit slave addressing
  for (uint8_t address = 8; address < 120; address++)
    bool printLine = printAll;
    bool found[speeds];
    bool fnd = false;
    for (uint8_t s = 0; s < speeds ; s++)
      TWBR = (F_CPU/(speed[s]*1000) - 16)/2;
      Wire.beginTransmission (address);
      found[s] = (Wire.endTransmission () == 0);
      fnd |= found[s];
      // give device 5 millis
      if (fnd && delayFlag) delay(RESTORE_LATENCY);
    if (fnd) count++;
    printLine |= fnd;
    if (printLine)
      Serial.print(millis());
      Serial.print(address, DEC);
      Serial.print(F("\t0x"));
      Serial.print(address, HEX);
        Serial.print(found[s]? F("V"):F("."));
  stopScan = millis();
  if (header)
    Serial.print(count);
    Serial.print(F(" devices found in "));
    Serial.print(stopScan - startScan);
    Serial.println(F(" milliseconds."));
that also didnot work , so i wish you help me
(deleted)
I'd recommend a cheap USB Logic Analyzer like: USB Logic Analyzer - 24MHz/8-Channel - TOL-18627 - SparkFun Electronics. You can hook this to the I2C and/or SPI bus and watch the traffic IN BOTH DIRECTIONS. Not only see what addresses the Master is talking to but see what the peripheral is saying back.
