Can i use bigger voltage on micro servo??
I have a Tower Pro SG90 Micro Servo, it says that with 5V the torque is 1,5kg/cm, if i put more voltage, will my servo have higher torque? Can i use a independet 9V 1A supply without burning it or the arduino board?
The servo just gets a control signal from the Arduino.
If you exceed the specs of the servo, you just burn it up.
They are geared device with built in electronics. Not like a DC motor where you can put in higher pulsed voltage to get more out of it.
Smug:
Most hobby servos are rated for 4.8 to 6.0 vdc, and you will get a little more torque and speed running at 6vdc. Going over 6.0 will only endanger the servo.
Some are rated upto 7.2V, it pays to check the actual manufacturer's data...
Can i use a independent 9V 1A supply without burning it or the arduino board?
You need to run the 9v thru a voltage regulator to keep the servo supply at ~6v. You can use a 7805 regulator chip with a diode like below to supply the servo with ~5.7v. Bottom is a way to wire a servo for external power.
