I have read through several methods of getting the bootloader onto an ATMega8 using the UNO as and ISP, but why can't I just put the ATMega8 directly into the UNO and select 'Arduino NG or Older with ATMega 8' as the board in the tools/board menu of the Arduino IDE ?
DuaneB:
Because there would be no hardware programmer working between the Arduino IDE and the Uno with a mega8 processor installed. Bootloaders must be programmed on a 'target' avr chip via its ICSP pins not the USB serial link. When you load a arduino board with the arduino-as-ISP sketch, it is acting like a hardware programmer talking to the IDE via serial but writing the bootloader code to the external AVR 'target' chip via the ICSP pin.
I think I have it now, based on your response and some subsequent searching -
When you upload a sketch, you're using the Arduino bootloader, a small program that has been loaded on to the microcontroller on your board. It allows you to upload code without using any additional hardware.
I will have a go at using optiLoader to put a boot loader on the ATMega8, I assume I can then put it into the UNO in place of the ATMega328 and upload test sketches.
Assumming this goes to plan I want to have a go at configuring the fuses to use the internal oscillator for some low cost projects.
