avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd9
تعذر الرفع: خطا اثناء الرفع exit status 1
was Nano just bought ?
Yes, 1week ago
Hi @mo77mo. Please try this experiment and then report back with the results:
This procedure is not intended to solve the problem. The purpose is to gather more information.
- Connect the Arduino board to your computer with a USB cable.
- Press and release the button on the Arduino board that is marked "RESET".
Now please reply here on the forum thread with the answers to the following questions:
- Did you see the LED marked "L" on the board blink immediately after you released the "RESET" button?
- Did the LED blink only once, or did it blink multiple times quickly immediately after releasing the button?
The LED marked "L" blinked multiple times
OK, this is a good sign. I'm going to ask you to post the full verbose output from an upload attempt.
Please do this:
- Select File > Preferences... (or Arduino > Preferences... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Uncheck the box next to "Show verbose output during:
☑compilation" in the "Preferences" dialog. - Check the box next to "Show verbose output during: ☐ upload".
- Click the "OK" button.
- Attempt an upload, as you did before.
- After the upload fails, you'll see a button on the right side of the orange bar in Arduino IDE: Copy error messages. Click that button.
This copies the full output to the clipboard. - Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the error output from the upload into the code block. - Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the "Reply" button to post the output.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\moham\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7b
avrdude done. Thank you.
There is a program named a "bootloader" that is stored in a special area of the memory in the microcontroller of the Nano board. The classic Nano (as well as its 3rd party derivatives) have been manufactured with two different types of bootloader installed.
You must configure the Tools > Processor menu in Arduino IDE according to which bootloader is installed on your Nano. Having the incorrect configuration selected in this menu is one of the potential causes of uploads failing with the "avrdude: stk500_recv(): programmer is not responding" error.
The multiple blinks on reset tell us that your Nano board has the modern bootloader installed.
I can see from the verbose upload output that you have Arduino IDE incorrectly configured for use with the Nano boards with the "old bootloader".
Select Tools > Processor > ATmega328P from the Arduino IDE menus to configure it for use with the modern bootloader and then try uploading again.
Hopefully this time the upload will finish successfully.
Using Port : COM3
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbb
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
- Disconnect the USB cable of the Arduino board from your computer.
- Select Tools > Port from the Arduino IDE menus.
- Take note of the ports, if any, listed in the menu.
- Close the Tools menu.
The ports list is only updated when the Tools menu is re-opened, so this step is essential. - Connect the Arduino board to your computer with a USB cable.
- Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
Select that port from the menu and try uploading again.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x02
when i plug the arduino in my computer IDE shows that my ardiuno is connected but once i upload the code the serial monitor shows that not connected and choosee a port and a board and after uploading complete and getting this error message arduino return to connect
I'm not sure I understood correctly what you mean by this. Let's try a different approach.
- Close the Tools menu if you have it open in the Arduino IDE menus.
- Leaving the USB cable of the board disconnected, select Tools > Port from the Arduino IDE menus.
Now please reply here on the forum thread with the answer to the following question:
- Do you see "COM3" listed in the "Port" menu?
No i can not see it, COM3 doesn’t exist in the port list
It is possible for a short or external circuitry connected to the Arduino board to interfere with the upload process, causing this type of upload error.
Make sure the board is not sitting on anything conductive that could short the contacts on the bottom of the board. Make sure there isn't any conductive debris (e.g., strands of wire or component leads) on the board or on the surface the board is sitting on.
If you have a shield or any external circuitry or components connected to your Arduino board, try this experiment:
- Disconnect any shields, modules, external circuitry, etc. from your board.
Now try uploading a sketch to the board again. Does the upload succeed?
This experiment will determine whether the upload error was caused by interference from your external circuitry. If so, you can then focus your attention on identifying the specific problem with the circuit and resolving it.
