Hi, I have the same problem but when I press the reset button I dont get a flashing light I just get a single flash and nothing more unless I press it again. Can you guide me what to try next or have I had a "magic smoke incident as you call it?
Hi @jeffrsharpe. The situation is somewhat different with the Nano compared to the Uno so there is still hope for your board.
I'm going to ask you to post the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Uncheck the box next to Show verbose output during: ☑ compilation in the "Preferences" dialog.
Check the box next to Show verbose output during: ☐ upload.
Click the "OK" button.
Attempt an upload, as you did before.
Wait for the upload to fail.
You will see a "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V.
This will paste the error output from the upload into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\jeffs\AppData\Local\Temp\arduino\sketches\F82651171BF7230C303F14B1D0BAAFA4/sketch_nov22d.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb7
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Thanks for quick response.....I am using my laptop for this response but I really want the nano to be working on a desktop in my observatory. Both machines give the same output as above except the laptop has a baud rate of 115200 and the desktop 57600. My nano is due to control the brightness of a light panel and I have had the software working on this laptop a month or so ago and I was hoping to set it up in the observatory desktop but the sketch wont work. Thanks for your help
OK, that is actually what I was hoping to learn from the verbose output. The classic Arduino Nano board (as well as its clones and derivatives) have been manufactured with two different bootloaders (a program stored on the microcontroller that is used to upload sketches to the board). One of these bootloaders ("Optiboot") produces multiple blinks after a reset and uses 115200 baud. The other bootloader ("ATmegaBOOT", AKA "Old Bootloader") produces a single blink after a reset and uses 57600 baud.
When using a board with the "ATmegaBOOT" bootloader, it is necessary to select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE menus to configure the IDE to upload sketches to the board at 57600 baud. Attempting an upload to these boards with Tools > Processor > ATmega328P (the setting for boards with Optiboot) selected is one of the possible causes of an upload failing with this "programmer is not responding ... not in sync" error message.
If you are getting the same error even when you upload at 57600 baud, that eliminates the incorrect IDE configuration as the cause of the error. However, you should still select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE menus anyway because the lack of multiple blinks on reset tells us you definitely don't have Optiboot on your Nano so the current incorrect menu selection would cause the upload to continue to fail even if we were to solve the primary cause of the upload failure.
With that out of the way, we can continue with the troubleshooting: This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
Disconnect the USB cable of the Arduino board from your computer.
Select Tools > Port from the Arduino IDE menus.
Take note of the ports, if any, listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Connect the Arduino board to your computer with a USB cable.
Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
Select that port from the menu and try uploading again.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
"C:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b57600 -D "-Uflash:w:C:\Users\jeffs\AppData\Local\Temp\arduino\sketches\0FF822AC440BC7E0A4B9096CF8573825/sketch_nov22c.ino.hex:i"
Using Port : COM3
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
"C:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\jeffs\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b57600 -D "-Uflash:w:C:\Users\jeffs\AppData\Local\Temp\arduino\sketches\E8726BF81743C49FB4EBC06BACD65FCE/Blink.ino.hex:i"
Using Port : COM3
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
I have a blinking nano on my laptop and on my desktop so Nano is working but my sketch for controlling the dimming of my A3 draghtsmans light panel and the mouse controlled graphics interface tool isnt working but I will work on that tomorrow....Many thanks for your very quick and thorough help. I have spent several hours trying similar options but obviously didnt get the right combination....Many thanks again...Thank you. Jeff
Nice! I guess the problem was only that you had the IDE configured for use with the Optiboot bootloader after all.
If you get stuck while troubleshooting the unexpected behavior of your sketches, feel free to ask for assistance here on the forum again. I recommend you to open a new topic in that event, since the subject is unrelated to that of this discussion about troubleshooting the "programmer is not responding ... not in sync " error while uploading.
You are welcome. I'm glad the upload is working now.
Just one final comment….I obviously have one out of three usb leads that wasn’t being recognised properly therefore the com port although showing as connected to Com3 was in fact not connecting and should have been Com4. So anyone following this thread be sure the Com port investigation routine above provided by Per is followed to check connectivity and be ready to try a second usb. Some apparently don’t transmit power.
